I start the bike, let it get up to temperature, get on it and start riding. As soon as the bike moves the needle on the temperature gauge drops to the position indicated with the red line in the picture. Is that where it's supposed to be when the bike is moving or should it be where the green line is in the picture?
I need some help regarding temperature.
- trifgeorge
- Level 2.0
So,
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
R6 pilot seat
KOSO mirrors
H1 HID
Re: I need some help regarding temperature.
The air passing through the radiator will cause the needle to drop.
When you say "bike moves the needle on the temperature gauge drops". Are you saying within a few seconds ?
- trifgeorge
- Level 2.0
Within a half a minute or so; sometimes even a minute.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
If you are finding that the temperature is fluctuation quickly you may want to check the thermostat, possibly a broken spring.trifgeorge wrote:Within a half a minute or so; sometimes even a minute.
- trifgeorge
- Level 2.0
The thing is that I already replaced the thermostat. Even so, there may be a small chance that the new one that I bought could be faulty as well. I'm going to buy another one. The thing is that I want to know where the needle should be when I'm riding. Shouldn't be where the green line is and stay there as the thermostat opens and closes to maintain the temperature?
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
Unlikely a new thermostat would be faulty (very simple device). Where your needle sits depends on the ambient temperature, condition of the radiator, coolant used, how lean/rich the engine is running.trifgeorge wrote:The thing is that I already replaced the thermostat. Even so, there may be a small chance that the new one that I bought could be faulty as well. I'm going to buy another one. The thing is that I want to know where the needle should be when I'm riding. Shouldn't be where the green line is and stay there as the thermostat opens and closes to maintain the temperature?
My gauge usually sits around a bit above 1/2 way when putting around and drops below 1/2 way on the freeway. At the lights/traffic slowly climb to a little over 3/4 until the fan kicks in.
yea. I would call this pretty normal...
Mine sits around there too, unless i am in traffic on hot day, then it goes up to about the 3/4 mark. But i personally wouldn't worry about this; Better than being too hot all the time!!
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
- trifgeorge
- Level 2.0
The thing that I'm worried about is that the first 100 miles that I rode it this year the needle was in the middle all the time (and it was by far colder than now) no matter if I was moving or staying still. Then one day I went for a ride and the needle didn't get upper than the red line shown in the picture. I replaced the thermostat and even so it still does the same thing. If I let it idle it will get up to the green line. The fan kicks in after after 10-15 minutes after I cold start it.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
- Level 2.0
As the temp guage is moved via resistance, its difficult to tell where it should sit, idealy as long as the needle never gets into the red you should be fine, the needle is never accurate just to add.
Seems pretty normal to me. Even here today it's in the 80's with high humidity and It sits at about half way unless I'm stopped for a while. Cool days I'm lucky if I get to the red line on that picture. I'd much rather have a cooler running bike than all that engine heat on a warm day
It really has to be a hot hot day before mine will go over half again this is without much stopping. I've rode my GF R6 and my best friends CBR and they run much hotter. So be thankful I guess.
- trifgeorge
- Level 2.0
I just bought another thermostat today. I'll mount it tomorrow and come back with feedback.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
I'm sure you've checked this, but if there isn't enough coolant in the system it won't contact the temperature sender and will result in a false reading. Make sure it's bled out properly.
