Idle issues
Idle issues
New here, just bought a 93 Fzr600 with 11,000 miles in pretty good shape. The bike runs and rides perfect but it will not idle. The previous owner said he cleaned the carbs 3 times and still couldn't get it to idle. It gets better when the bike warms up but it will idle down to about 800 then stall.
Where do I need to start looking? The bike is completely stock also and it seems to run just a little rich.
Sent from my Motorola Electrify using Tapatalk 2
Re: Idle issues
First; did you try to adjust the idle speed yet?
*The Idle Adjustment screw is a Tiny Knob near the Fuel Petcock (have to reach your hand inside the fairing in front of the fuel petcock). Turning it clockwise raises the idle.
Why do you think it is running Rich?
let us know.
let us know.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Idle issues
I was going to try and adjust the idle this evening. You can smell fuel pretty good
If you are standing behind it and if you rev it really good it will smoke just a bit.
Re: Idle issues
You might consider Checking/Cleaning the Sparkplugs. Its amazing how much clean spark plugs help.
But first adjust the idle and let us know.. its easy.. i do it a stop lights often...
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Idle issues
Ok, I'll try that and report back. He also mentioned it had new plugs because he kept getting them soaked in fuel. I think he showed me that screw and was saying it was a mixture screw and if you adjusted out any higher the bike will rev higher and hang when you shift.
Re: Idle issues
That is interesting as we just discussed this "Hanging RPM" in a post viewtopic.php?f=8&t=9590 about erratic idle. The problem was Intake Leaks causing inconsistent airflow.apwcu wrote:I think he showed me that screw and was saying it was a mixture screw and if you adjusted out any higher the bike will rev higher and hang when you shift.
Anyway, if what he showed you was a single knob that you could grab with your hand; it was the idle adjustment screw. When the bike is at operating temperature you Need to set your idle using this screw to about 1,200 rpm.
Now if the bike is 'Hanging' before it comes back down to 1,200rpm, then you very well might have a vacuum leak and/or need to tune the Air/Fuel mixture screws. * Again refer to the link i posted above.
NOTE: The Mixture screws are actually on the carbs; there are 4 of them.. They are used to control the mixture of Fuel/Air the Pilot jet supplies the engine. -It's very possible that you'll have to tune these on your bike; But first you would have to Set the Idle correctly, Identify if you have any Vacuum Leaks, and Sync the Carbs.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Idle issues
I forgot to mention that he told me he thought the problem was the diaphragm sliders in the tops of the carbs.
Re: Idle issues
Well I messed with the idle screw and all that did was make it hang even worse between shifts. Where should I start looking for vacuum leaks?
Would unsynchronized carbs cause this? The bike does run very well, even if you're coasting and pull the clutch in the bike will sit around 1100 and won't die.
Thanks for the help.
Re: Idle issues
The most common Vacuum Leak area is the Intake Boots. Basically pull the gas tank out of the bike, set in on a stool next to the bike, start the bike, and spray Starter Fluid around the intake boots. If the RPMs increase while doing this you have a Vacuum leak in the Intake Boots. Either they are Not Sealing or Cracked. I just replaced mine the other day. (perform this while the bike is warm)
Again see the link i posted above.
Once you check the intake boots as described, the next steps would be Syncing Carbs and Adjusting Mixture Screws.
Again see the link i posted above... Haha
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Idle issues
Correct me if I am wrong, but isn't starter fluid flammable ?
Maybe some thing like WD40 would be a bit safer and achieve the same results.
pnbell wrote:The most common Vacuum Leak area is the Intake Boots. Basically pull the gas tank out of the bike, set in on a stool next to the bike, start the bike, and spray Starter Fluid around the intake boots. If the RPMs increase while doing this you have a Vacuum leak in the Intake Boots. Either they are Not Sealing or Cracked. I just replaced mine the other day. (perform this while the bike is warm)
Re: Idle issues
Yea, it's flammable.. That's the Point! Ha ha!!
I mean we're not spraying it into an open flame, and very little spray is needed for the test. But i mean basically this is the intended purpose of Starter Fluid...
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Idle issues
Well I tried the starting fluid and I didn't notice any change in idle. I may try synching the carbs, is it hard to do?
Re: Idle issues
Not really, just need the right tool.apwcu wrote:Well I tried the starting fluid and I didn't notice any change in idle. I may try synching the carbs, is it hard to do?
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
