Best location to splice engine temp sensor
- Level 2.0
Re: Best location to splice engine temp sensor
I think my new plan was to somehow avoid the splice into the hose, and go right for the wires, or actually use te vapor sender piece to replace the stock one. Seems like it would be the most accurate for the engine/warning temp.
http://motopreserve.com is a blog about wrenching on bikes in Brooklyn.
1993 FZR 600. A work in progress...
That will work, and is the only way to go.nortstudio wrote:or actually use te vapor sender piece to replace the stock one. Seems like it would be the most accurate for the engine/warning temp.
Already covered and solved in a previous thread, who I wonder solved the issue
- Level 2.0
Have a link? I searched before I bought the thing and didn't find anything???
I can't find the thread either. The search engine on most forums is not too good. No offence intendednortstudio wrote:Have a link? I searched before I bought the thing and didn't find anything???
Remove the stock sender unit (circled in Orange below) and replace it with the vapor sender unit, I know others have attempted to steer you on the same path
- Level 2.0
Yep, others have tried, and I tried to follow. I just thought maybe you had a thread with some details. I think I'm good though now.
Thanks.
Scott
Thanks.
Scott
You SIR are welcome.nortstudio wrote:Yep, others have tried, and I tried to follow. I just thought maybe you had a thread with some details. I think I'm good though now.
Thanks.
Scott
