The Build
Re: The Build
I actually have those filters and they didn't work as well as I wanted, and I saw another thread on her using the stock air box boots to lengthen the intake but the pods don't fit bc I didn't have an old airbox to take the boots from and the closest thing I could find was much longer, which means that the pods don't fit as is
There are no small days.
Re: The Build
Fair enough - my point was not that you have to duplicate exactly the typical Uni dimensions, but rather that you need as much surface area as you can get, and what you have isn't nearly enough ...
- Level 8.0
Re: The Build
looks great, i like the color scheme
NO FZR
05 Yamaha R1
03 Harley Fatboy
what's next?
05 Yamaha R1
03 Harley Fatboy
what's next?
- Nunya_Binnez
Re: The Build
That paint looks GREAT!
Mind if I ask what she charged you?
NDB
NDB
1993 FZR600 (Currently doing a frame-off buildup)
Nunya's '93 Resto-mod Build [TMI?]
"When life gives you lemons...you probably just FOUND lemons." - Bo Burnham
- Nunya_Binnez
Re: The Build
Is that your fairing being painted on the PBC homepage?
NDB
NDB
