98 fzr600 dies/ sputters / sucks
its hard to get the bike to start and when it does it dies as soon as you put it in gear. i rode the bike once and it kept dying i had to turn it off and back on
Re: 98 fzr600 dies/ sputters / sucks
Sounds like you have a few things going on there. The hard-to-start could be carbs, or it could be tight intake valves - insufficient clearance means the valves don't seal, you lose cranking compression, and the bike doesn't start. The "shuts off immediately" could be carbs (again), improperly adjusted clutch, or a bad connection in the safety system (probably the side-stand switch).
Pull, strip and clean the carbs, including a bench synch.
Adjust the clutch.
Check the valve lash.
Check the function and security of the sidestand switch and connector.
Should take you a lazy weekend with a friend and a few cold beverages of choice.
Adjust the clutch.
i cleaned the carbs, tuned them, bypassed the kickstand switch, now it just dies on the interstate but runs good threw town?
THAT is a clogged tank vent. Pull and clean the little passages in your gas cap.
what if it has a r6 tank
Same thing - the issue is the vacuum being drawn down, not the shape of the tank.
ok vacuum lines are cleaned and still doing it, its almost like its the coils. i was reading about swapping the coils and i noticed mine are not stock but not escort or that type of coil?
problem fixed it was 2 crossed wires. wow this bike runs!!!
Crossed wires???
Do you mean coil wires or something else.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
spark plug wires
