Brake swap
biff10
Brake swap
Post by biff10 »
I see where people are talking about using the r-6 stuff. Can some one give me exact parts that work and what are bolt on? I want master,calipers and rotors for sure and maybe do a fork swap at the same time. Does the front wheel have to be changed if I only do brakes?? Rotors and calipers??
1992 FZR 600 black
thatkid
Re: Brake swap
Post by thatkid »
viewtopic.php?f=18&t=9292
Still for sale.
Aftermarket rotors are available for the FZR but they are pricey..as with any rotors really. They run about 300+ per rotor.
Do YOU Scopper?
biff10
Re: Brake swap
Post by biff10 »
I sent you a pm. That is almost everything I want. Just want rotors also.
1992 FZR 600 black
thatkid
Re: Brake swap
Post by thatkid »
biff10 wrote:I sent you a pm. That is almost everything I want. Just want rotors also.
Never got the private message. I can get you aftermarket rotors but like I said they are about 300 a piece.
Do YOU Scopper?
biff10
Re: Brake swap
Post by biff10 »
So what year do yzf 600 parts work to bolt directly to the 92 fzr 600 I own????? I have a guy with parts so I am looking for the exact year of what bike works????
1992 FZR 600 black
cowboi
Level 2.0
Level 2.0
Re: Brake swap
Post by cowboi »
Nate , that kit there are you dead set on keeping it together as I have the mc and res already so I dont need them. Also gonna need that neck bracket we talked about awhile back.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
biff10
Re: Brake swap
Post by biff10 »
So does that have anything to do with the question I have asked???
1992 FZR 600 black
cowboi
Level 2.0
Level 2.0
Re: Re: Brake swap
Post by cowboi »
biff10 wrote:So what year do yzf 600 parts work to bolt directly to the 92 fzr 600 I own????? I have a guy with parts so I am looking for the exact year of what bike works????
It depends on what parts you want to replace which would determine the year of the bike. But as there is only a limited number of parts that actually are direct bolt on it would help us if you gave us an idea of what your trying to replace or maybe an idea of what your trying to do.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
cowboi
Level 2.0
Level 2.0
Re: Re: Brake swap
Post by cowboi »
biff10 wrote:I see where people are talking about using the r-6 stuff. Can some one give me exact parts that work and what are bolt on? I want master,calipers and rotors for sure and maybe do a fork swap at the same time. Does the front wheel have to be changed if I only do brakes?? Rotors and calipers??
As for the breaks...... check the wiki and I know that there's already several topics that cover this already. But just a hint. Blue dot calipers are about the only direct bolt on's there are. And blue dots go from 90's to almost present.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
Re: Brake swap
Post by sweekster »
You'll want to do a search for more info. I, among others, have answered this several times over. With that said, blue dot, gold dot, and silver dot non radial Sumitomo calipers are the only yamaha oem spec'd parts that are considered "bolt on". These can be found on the yzf600, fz1, fz6,r1, and r6. There are some Nissan calipers that will bolt on but I don't know off hand. The only ones of the them that have any real performance gains are the gold spots due to the pistons being lighter and Teflon coated. The others really have nothing more than cosmetic value. The "upgrade", if you will, is in the master cylinder. You can get the same effect with, for example, an r6 radial master and the stock calipers. Now, the masters are not bolt on due to the fzr not having a mount for the reservoir but the can be overcome easily. Hope that helps. For rotors click here: http://fzronline.com/wiki/doku.php?id=brakes600.
biff10
Re: Brake swap
Post by biff10 »
Thanks sweekster, I have a guy in town that parts out bikes. I also have been reading about the rear swap. I think this guy may have all the parts I need now that I know which bike to look for.
1992 FZR 600 black
