Oil usage and new rear shock???
I hope you guys can help...
My 1994 1000EXUP RU has about 48,000 miles on it and does use a fair bit of oil. Over 1000 miles has used about 1 litre of oil. I know these bikes do use a bit but is that sort of consuption usual?
In addition my rear shock is getting on a bit with nearly 50K of use on it, has anyone got an idea of a reasonably priced shock or one that will bolt on from another bike like a busa or R1?
The bike didn't cost alot (ie, £700) so spending £500 on a brand new Ohlins or even £300 on a Hagon really isnt an option!
Any help would be appreciated.
cheers!
cheers!
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
Re: Oil usage and new rear shock???
My first engine used a sh!te load of oil too. What oil are you using? Some say using mineral oil is the way to go as it helps the rings seal.
The engine I have now is a 1040 and the pistons and rings have about 6000 miles on them, no excessive oil use at all now. In this engine I use semi-synth. I'd try the mineral oil for a 1000miles and see if it helps, if not it's probably overhaul time or just put up with it.
Re: The rear shock. You are in the UK so if you search for Brooke Suspension give them a call. They should be able to (I am awaiting a reply) refurb your existing shock for around £100.00. They have an eBay ad too. Not many other shocks are the same length as the exup's shock. You could find a similar length shock then mess with different length dog bones I suppose. Or just keep your eye out for a second hand low miles ebay special.
cheers,
i use semi-synth at the mo as per recomendation from my local bike bloke. at least by permanantly checking and topping up my oil it means the bike allways got fresh oil in it!
a shock refurb is somthing ive looked into but mine is in quite a state. the springs paint has flaked in most places and is a bit rusty! all the second hand ones ive seen are in similar condition so it feels like im lobbing money at something no better than what i already have.
i've got three different lenths of dog bones as it is as i have played with the ride hight i bit and alot of newer shocks have built in ridehight adjusters so prehaps if i got a shock with preload/damping and ride height adustment of a similar length it may fit ok.
not sure though. will have to ponder and do some more homework i suspect.
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
If you PM me your email address I can send you a list of loads of different shock lengths/stroke etc.
cheers, that would be helpfull.
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
Gizzard1533
- Level 2.0
Your oil burning problem could be valve stem oil seal related, piston rings or even head gasket. Too make sure it is the head gasket, do you have blue smoke coming from the exhaust and on the bottom of your oil filler cap, is there a creamy substance on there? if none of these its not likely your head gasket. Most likely its your valve stem seals.
As far as shocks go, is it leaking oil? Does the rear bounce a few times? If none on these and if just looks nasty, unless you want a shiney one i wouldn't worry, you could just take if off and paint it?
hi,Gizzard1533 wrote:Your oil burning problem could be valve stem oil seal related, piston rings or even head gasket. Too make sure it is the head gasket, do you have blue smoke coming from the exhaust and on the bottom of your oil filler cap, is there a creamy substance on there? if none of these its not likely your head gasket. Most likely its your valve stem seals.
not sure about a 1K fzr but the 600 guys have done alot of write ups on rearend shock swaps and there is stuff in the Wiki too.
Reelrazor used to do kits for the US crowd.
W.F O
Nik H.
There are two kinds of posts on Forums.
1. This is what I have done...
2. This is what I think...
Be aware of the difference!
Nik H.
heres a list of alternative shock lengths thats been flying around our site for some time. You may find something compatible out of this lot
Quadclown wrote:
As far as I've found out the bikes OEM shock is
340 mm from center eye to center eye and has a
stoke of 70 mm ( same as my YZF 750 ).- - - - - -
Shock Length Chart
This chart is a useful starting point for anyone
wanting to replace the standard shock in their
bike. You will obviously need to match up length
and stroke of your bikes shock as closely s
possible - be careful though, this chart does not
cover top and bottom shock mount types,
reservoir type and position, spring rates or
internal valving
Make Model Year Shock Length
(mm) Shock Stroke
(mm)
Suzuki Bandit 600 2000-2004 319 55
Suzuki Bandit 650 2005 319.5 65.5
Suzuki Bandit 1200 1996-2000 306 64
Suzuki Bandit 1200 2001-2005 320 (+6/-0) 61
Suzuki GSXR 600 1992-1993 312 (+12/-0) 67
Suzuki GSXR 600 2001-2003 325.5 (+6/-0) 74
Suzuki GSXR 600 2004-2005 332.5 (+6/-0) 74
Suzuki GSXR 750 1985-1987 290.5 61
Suzuki GSXR 750 1988-1991 312 (+12/-0) 67
Suzuki GSXR 750 1992-1995 312 (+12/-0) 67
Suzuki GSXR 750 1996-1999 356 (+6/-6) 79
Suzuki GSXR 750 2000-2003 325 (+6/-0) 74
Suzuki GSXR 750 2004-2005 332.5 (+6/-0) 74
Suzuki GSXR 1000 2001-2002 329.5 (+5.5/-0.5)
74
Suzuki GSXR 1000 2003-2004 332.5 (+6/-0) 74
Suzuki GSXR 1000 2005 319 70
Suzuki GSXR 1100 1986-1988 315 69
Suzuki GSXR 1100 1989-1992 312 70
Suzuki GSXR 1100 1993-1998 312 70
Suzuki Hayabusa 1999-2006 330 72
Kawasaki ZX6R 2003-2004 340 (+12/-0) 72.5
Kawasaki ZX6RR 2003-2004 340 (+12/-0) 72.5
Kawasaki ZX6R 2005 335.5 (+12/-0) 64.5
Kawasaki ZX6RR 2005-2006 330 (+12/=0) 63.5
Kawasaki ZX7R 1996-2001 350 (+12/-0) 75
Kawasaki ZX9R 1994-1997 348 79
Kawasaki ZX9R 1998-1999 330 (+12/-0) 69
Kawasaki ZX9R 2000-2001 338 67
Kawasaki ZX9R 2002-2003 338.5 67.5
Kawasaki ZX10 1988-1989 314.5 67
Kawasaki ZX10R 2004-2005 338 (+7/-5) 69
Kawasaki ZX12R 2000-2005 338 (+7/-5) 67
H*nda CBR 600 F 1987-1990 292 50
H*nda CBR 600 RR 2003-2006 313 (+0/-6) 59.5
H*nda VFR 800 FI 1998-2001 325 58
H*nda VFR 800 FI 2002-2005 317.5 53.5
H*nda CBR 900 RR 1992-1995 319 (+12/-0) 54
H*nda CBR 900 RR 1996-1997 305 (+12/-0) 60
H*nda CBR 900 RR 1998-1999 303 (+12/-0) 57
H*nda CBR 900 RR 2000-2001 286 (+4/-2) 57
H*nda CBR 900 RR 2002-2003 288 (+2/-4) 57
H*nda CBR 929 2000-2001 286 (+4/-2) 57
H*nda CBR 954 2002-2003 288 (+2/-4) 57
H*nda RC51 2000-2005 326 (+10/-2) 63
H*nda CBR 1000 RR 2004-2006 314 (+6/-0) 58
H*nda VTR 1000 F 1997-2005 346 60
H*nda VTR 1000 SP1 2000-2001 326 (+10/-2) 63
H*nda VTR 1000 SP2 2002-2005 326 (+10/-2) 63
H*nda CBR 1100 XX 1997-2005 319 52
Yamaha YZF 600 1994-1999 360 (+12/-0) 70
Yamaha YZF R6 1999-2002 305 (+4/-2) 62
Yamaha YZF R6 2003-2004 295 (+5.5/-0.5) 62.5
Yamaha YZF R6 2005 300 (+0/-6) 62.5
Yamaha FZR 750 1987-1988 300.5 54
Yamaha FZR 750R 0W01 1989-1991 360 76
Yamaha FZR 1000 1987-1988 300.5 54
Yamaha FZR 1000 1989-1995 340 70
Yamaha YZF 1000 1996-2000 340 (+12/-0) 69
Yamaha YZF R1 1998-2001 300 (+11/-1) 65
Yamaha YZF R1 2002-2006 300 (+5.5/-0.5) 64.5
to help with some of the GOTCHA's you might find this helpful:-
http://www.saltmine.org.uk/fzr/3tj-mod.html
Towards the bottom of the page
That's all a great help and very much appreciated, thankyou all.
i know my head gaskets not gone at least as there is no mayo round the oil cap! one saving grace thats for sure!!
the bike does smoke a bit on start up but that is white and clears when the engine is warm.
i have been told when i'm out on ride with some mates that when i give it the beans there is a bit of blue smoke under heavy accelaration but i wonder how much of that is burnt old oil in the wadding of the end can as that scorpion has been on the bike for 10 years (i'm repacking it shortly as im sure it past it best anyway).
it's all the fun of owning an 18 year old bike!!
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
just out curiosity ive seen a shock adapter for a 2006> r6 rear shock. basicaly the r6 shock is 30mm shorter than a 1000exup unit and this compensates. apparently its a 30 min job to fit the whole lot and get a far newer and more adjustable rear end.
has anyone tried this? link below.
http://www.projection-components.co.uk/ ... s-17-p.asp
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
Hi C,crowe wrote:just out curiosity ive seen a shock adapter for a 2006> r6 rear shock. basicaly the r6 shock is 30mm shorter than a 1000exup unit and this compensates. apparently its a 30 min job to fit the whole lot and get a far newer and more adjustable rear end.
That looks substantially built and looks that it could do the business for you at least as far as the engineering concept part goes.@ 40 quid it is not cheap but having it custom made would be minimum of 80 quid so yes what the heck give it a try. Just be sure that the torque values for the bolts are met !
With my Site Directors hat on do me a favour if you go this route WRITE it up for the WIKI
( or send me pictures and a brief description of what each shows at what stage of work Plus your thoughts on the suppliers service level would be nice. if you do not fancy the WIKI edit bit I will do it for you )
Y-Geo.
If i do do this i will certainly write it up as i think it may be a usefull bit of knowledge (budget is as always at this time of year is tight) but it's something that will need doing at some point.
With a cost of around £150 all in with a far newer multi adjustable shock in place, would be rude not to try!!!
Lets face it, the old exups are a dying breed so anything to keep 'em alive 'n kicking has got to be worth it.
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
my only comcern about using the R6 shock is that the spring weight may not be up to the task. The R1 spring may be more suitable especially when you consider the weight difference of the R1 to the Exup1000
Paul,Stig wrote:my only comcern about using the R6 shock is that the spring weight may not be up to the task. The R1 spring may be more suitable especially when you consider the weight difference of the R1 to the Exup1000
true but at this point he would be guessing about the ride quality anyway . Sit on it, ride it, he will know which way & probably a better guess as to what will work . Unless of course he knows where a good suspension guy hides to ask that is:-}
