i just removed my voltage regulator and notice that one of the lower male terminals looks like it is burnt ( im downloading pic) can someone verify if its time for me to do the upgrade of the voltage regulator the connector its self is in good shape (not burnt). keep me
VOLTAGE REGULATOR FRIED ?
HELLO EVRYONE,
thanks Dayalalito
Re: VOLTAGE REGULATOR FRIED ?
Why risk the chance of major damage to your entire electrical system by keeping it? Swap it out with the much better designed VR.
Do you know what the terminal controls, im going to change it as the bike doesnt want to start anyways so why not upgarde
thanks Dayalalito
Looks like one of the WHITE wires that comes from the stator.dayalalito wrote:Do you know what the terminal controls, im going to change it as the bike doesnt want to start anyways so why not upgarde
thanks for the info, looking at my VR its diffrent from yours, but im sure internally its the same , mine has vents on top (looks like a radiator)
thanks Dayalalito
Ah you have the cheap copy with the cooling finsdayalalito wrote:thanks for the info, looking at my VR its diffrent from yours, but im sure internally its the same , mine has vents on top (looks like a radiator)
Time to inspect what if any damage that POS has done to your electrical components, best place to start is here http://fzronline.com/wiki/doku.php?id=no_spark_now_whatdayalalito wrote:Do you know what the terminal controls, im going to change it as the bike doesnt want to start anyways so why not upgarde
FYI that POS VR (the finned cheap copy) is well known to take out the TCI, Tacho, Fuel pump, and more. I hope your more fortunate.
Good luck.
Most things can be fixed "stupid" is unfortunately beyond repair
will order an updated VR, and will see if anything else is fried, tacho dont have to wprry about because the bike didnt have on from the start , will check Fuel pump and let everyone know
thanks Dayalalito
