Throttle Cable
- jsph.mitch
- 100+ Posts
Throttle Cable
On my way homefrom work tonight, I snapped my throttle cable. No fun when you're going along at 50mph in town traffic. Looks like I need a cable now.
Sent from my ADR6300 using Tapatalk
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Many more mods to come.....
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: Throttle Cable
I would agree with that assessment. I'd sell you my used ones, but it's probalby more worth your time to just buy new.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: Throttle Cable
. Buy some motion pro cables for like 15 bucks with free shipping on eBay. Real quick shipping.blensen wrote:I would agree with that assessment. I'd sell you my used ones, but it's probalby more worth your time to just buy new.
Re: Throttle Cable
had that happen to me going down the interstate one morning, having friends with trucks is always good. Don't forget to put some lube down both the cables
- jsph.mitch
- 100+ Posts
Re: Throttle Cable
Finely had the time to remove the cable. The cable was chewed up on the top. Looks like its been that way for a while. I think I am going to check the salvage place in town. If they don't have it, I will order it.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: Throttle Cable
For 15, I would just go new.
Sent from my NookColor using Tapatalk
'92 FZR600
Lots of Powder
Lots of Powder
Re: Throttle Cable
+5 on the new unless you like the workout of pushing your FZR up ramps.delvryboy wrote:For 15, I would just go new.
- jsph.mitch
- 100+ Posts
Re: Throttle Cable
I broke the pull cable, but found the push and pull cables at the motorcycle warehouse in Auburn Maine. The Guy gave me a heck of a deal. 5 dollars on the pair. They were off a 95 far. Very good shape. I had to mod the bracket the push side sits in, but works 100%. Now if I could just get the damn thing started.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: Throttle Cable
J,jsph.mitch wrote:I broke the pull cable, but found the push and pull cables at the motorcycle warehouse in Auburn Maine. The Guy gave me a heck of a deal. 5 dollars on the pair. They were off a 95 far. Very good shape. I had to mod the bracket the push side sits in, but works 100%. Now if I could just get the damn thing started.
has this hard start prob been since the cable broke?
If so you might want to check the carbs are seated correctly and are "Bench" synched with the new cables in place and not stuck closed /open. Just a thought.........................
- jsph.mitch
- 100+ Posts
Re: Throttle Cable
I had to take the carbs off to mod the bracket for the push cable. Other than that, nothing else has been done to it. Last time it ran was the day my cable snapped. That was over a week ago.
Sent from my Droid Incredible using Tapatalk.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: Throttle Cable
J,jsph.mitch wrote:I had to take the carbs off to mod the bracket for the push cable. Other than that, nothing else has been done to it. Last time it ran was the day my cable snapped. That was over a week ago.
it has been my experience that the "last thing " done before something breaks is the culprit,
you may wanna look in the area you last worked on in case you "disconnected" some wires or those carbs are not sitting as they should
- jsph.mitch
- 100+ Posts
Re: Throttle Cable
YG
I took everything back apart, cleaned all the contacts, replaced the ground wire, and added one, and put it all back. Still the same slow starter. The red hot wire coming off the battery gets hot while cranking it. While I had it apart I hit the starter wire directly on the battery and it cranks the same. Could the starter be going out? Is there a way to test it?
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
