led lights
floridafzr600
led lights
do 94 yzf led turn signals for the front. are they just plug and go
Re: led lights
Sure. Just make sure you're using the correct wires. One will give significantly brighter than the other. I can't remember which is which offhand.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: led lights
Blue is running light, Black is ground; Green or Brown ("Chocolate") is the signal for that side.
Re: led lights
What would we do without you, Don?
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
floridafzr600
Re: led lights
thanks everyone but don what do i do if the led lights are only a two wire
Re: led lights
Ignore the blue (running light) wire. Hook up the hot bike wire to the hot LED light wire, and ground to ground.
blensen - You'd get by, just not as well ...
floridafzr600
Re: led lights
thanks i didnt know if it would be that easy or if i had to do resistors and what notDonTZ125 wrote:Ignore the blue (running light) wire. Hook up the hot bike wire to the hot LED light wire, and ground to ground.
Re: led lights
Depends on the arrangement. Some LEDs have built-in ballast resistors; some need to be added to slow the blink rate. The other option is to splice in a flasher relay meant for LEDs, but you'll lose the self-cancelling function of the OEM system.
floridafzr600
Re: led lights
ok fzr 600 has 3 wire the lights have two is there a way i can still make it with running lights too or am i just stuck with turn signals only
CortezLoetz
Re: led lights
The other option is to splice in a flasher relay meant for LEDs.
_____________________________
fluorescent led bulbs
led ceiling lights
led strip lighting
led ceiling lights
led strip lighting
