Fuel pump question?
blackeyesandbruises
Re: Fuel pump question?
Post by blackeyesandbruises »
what would cause that a bare wire that is making contact? sorry full of questions.
It consumes me....
dru86
Level 1.5
Level 1.5
Post by dru86 »
There should be one click form the relay when you turn the ignition on, then the fuel pump should prime for UP TO 5 secs. The smoke coming form the rear is quite likely to be your voltage regulator crapping itself, when they go they can cook the fuel pump and/or relay. Do as has been previously stated here test the fuel pump first by disconnecting the fuel line going from it to the carbs, placing it into a container and turning the ignition on, fuel should then come out. If this doesn't work apply 12v directly to the two wires for the fuel pump, if it still doesn't work the fuel pump is shot. I'd also advise testing your regulator.
emily rose
Post by emily rose »
Hello everyone I have a 1992 fzr 600 It will not start. It getting a spark So i check to see if it was getting fuel, it wasn't. I hook the fuel pump up to the battery an it work. So why isn't it getting ANY juice is it the relays or regulator.help help help
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
emily rose wrote:Hello everyone I have a 1992 fzr 600 It will not start. It getting a spark So i check to see if it was getting fuel, it wasn't. I hook the fuel pump up to the battery an it work. So why isn't it getting ANY juice is it the relays or regulator.help help help
starter relay could be bad
Upgrades:
emily rose
The starter relay. Do you know of a way i could check. Because it does turn over it just doesn't start.No power to the fuel pump.Thank you for the helping hand
DonTZ125
Moderator
Post by DonTZ125 »
If the engine cranks and sparks, the starter relay is fine. You've already checked that the pump itself works when directly connected to +12v - good so far. What you need to check now is the main relay assembly, a small black pack on the left side of the bike by the battery with a strange 11-pin connector (12 positions, one of which is the latch).
Hook +12v to the Red/White wire, and Ground to the Black/Blue. Measure resistance between the Red/White wire terminal and the Blue/Black - you're looking for continuity. No continuity = the fuel pump relay (inside the assembly) is dead and the assembly must be repaired or replaced.
If that passes, check for continuity through the Black/Blue wire at the relay connector and at the TCI connector (bottom-center pin on the 6-pin TCI connector). No continuity = a damaged wire.
If everything is ok so far, you're probably looking at a damaged TCI box. Make sure the TCI connectors are hooked up, then connect the continuity checker between the Black/Blue pin in the relay connector and ground. Turn the key and kill switch on; you should get continuity through the pump relay circuit for 5 seconds before it shuts back off. If this fails, the pump switching transistor in the TCI is fried, and the TCI must be repaired or replaced.
emily rose
And you know what my damn flashers are not working. Thanks for the help on the pump. Now i know where to start.
emily rose
Well i found out why my fuel pump was not getting any juice. When i grounded the ground wire that goes to the relay the juices started flowing.
DonTZ125
Moderator
Post by DonTZ125 »
Which wire - the Black / Blue? Have you tested it for continuity to the TCI connector, and then THROUGH the TCI?
CJD
Post by CJD »
DonTZ125 wrote:Which wire - the Black / Blue? Have you tested it for continuity to the TCI connector, and then THROUGH the TCI?
Sorry for jumping in here, but there is NO red/white wire connected to the Main Relay (your earlier post), However there are 2 black/blue wires connected to the relay,
Which of the 2 black/blue wire's should be tested? im confused :headscratch:
emily rose
Well i had a test light an i was go threw the wires on the relay just to see which one had juice. So when i touch the black one i heard the fuel pump come on.The black wire that goes to the fuel pump to the relay.
emily rose
No i haven't tested tci box yet today when i get off i will. Thanks Dontz125
DonTZ125
Moderator
Post by DonTZ125 »
Bloody model year differences... Ok - for the '91+ US FZR600, hook up +12v to the Red / BLACK wire and ground to the Black / Blue wire; this Black / Blue wire is also the wire to check for continuity to / through the TCI. Check for relay continuity between Red / Black and Blue / Black wires with +12v applied to the relay coil.
There aren't 2 Black / Blue wires; there is one Black / Blue and one Blue / Black. The difference after 20 years of weathering and fading may be difficult to see; thank the idiots in the Yamaha wiring department.
CJD
Post by CJD »
DonTZ125 wrote: There aren't 2 Black / Blue wires; there is one Black / Blue and one Blue / Black. The difference after 20 years of weathering and fading may be difficult to see; thank the idiots in the Yamaha wiring department.
I stand corrected Sir :notworthy:
