just got my first road bike, fzr600, 1989, ive been head over heels for these bikes since i was about 5, when my dad had one and ive been managed to grab one which is pretty much exactly the same as his that we can both strip and restore!!
I bought the bike off ebay as a non-runner/starter. it has pretty much full tax and mot and has been used reguarly until it wouldnt start one day...hence the sale.
i have now started to look for what thye problem is.... i have, so far tried...
engine turns over fine when tring to start, the most youll get is a backfire.
checked all 4 plugs all ar ok. and all are sparking when you try to start.
i have taken off main fuel hose to carb fuel fail, turned to run and this spurts out fuel for about 4 secs and looks like a priming sequence.
i then put back together and tried to start... still the same.
i suspected lowq fuel pressure or a blockage in the fuel rail maybe, so i put a little fuel into each carb via air inlet and tried again, still not even a splutter
any ideas??? i was sure id get at least a caugh out of it but nothing. as this is my first bike i dont know much about the tech side of things so help would be much appreciated.
heres the beast....
aaron.
