got another guess the brand
jos21802001
Post by jos21802001 »
of you did so good on my last one. lets see what I can find out on it . This header doesn't look stock to me but i can be wrong. It is on my 1989 yamaha FZR600. Kept in mine this was a bike raced up at Summit Point and I bought it and put it back on the street.It fits under fairing but really close to the right on also had to trim out bottom of fairing where meets mid pipe.
1989 fzr 600 candy silver base coat, black frame ,voltage up-grade amoung much more :)
Target30
Level 7.5
Level 7.5
Re: got another guess the brand
Post by Target30 »
to be honest it looks like an Vance and Hines SS2R full system header, but it doesnt have the spring hooks on it
I did that.
jos21802001
i was thinking the same when i started looking at it the only thing that throws me is it goes stright back then kick of to the left at 45 degrees
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
Vance and Hines i'd say
Upgrades:
FasterThanUr
100+ Posts
100+ Posts
Post by FasterThanUr »
Thats a Muzzy I believe.
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
jos21802001
why can't they just badge them from the start lol
FasterThanUr
100+ Posts
100+ Posts
I think they have a S/N # stamped on them but it probably rusted off.
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
thatkid
Post by thatkid »
That's the lower model vance and hines header. The supersport I believe. The ss2r has removable end pieces that bolt to the head first and then you slide the header pipes over them and use the springs to secure it. The muzzy offsets the stack at the collector where the V&H puts them right over each other.
Do YOU Scopper?
jos21802001
sweet to think i though it was stock at first before i took it off and started sanding it and respraying lol
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
thatkid wrote:That's the lower model vance and hines header. The supersport I believe. The ss2r has removable end pieces that bolt to the head first and then you slide the header pipes over them and use the springs to secure it.
Less expensive model, but certainly better sounding and I would wager higher performance than the SS2R.
