swaying in hard corners
megaloxana
Post by megaloxana »
Alright so I just got back from the first decent ride I've had all year as Im trying to fine tune the carbs. Anyway Im taking a hard corner on some pretty decent road, dont remember how fast(50-60?). So the bike starts to sway as I'm taking this turn.
This is the first time I noticed this and I've ridden much harder before.
what could cause this?
Suspension is stock except for the dogbones which raised the bike. Tires have less than 600 miles on them.
The front suspension is pretty soft(duh) and the rear shock doesn't seem too bad(i weigh 140lbs).
'92 FZR 600
tommyj27
Level 9.5
Level 9.5
Re: swaying in hard corners
Post by tommyj27 »
silly question, did you check your tire pressure?
megaloxana
tommyj27 wrote:silly question, did you check your tire pressure?
will tonight :thumbsup:
'92 FZR 600
shift
Level 1.5
Level 1.5
Post by shift »
your new tires don't happen to be the continental attacks, do they? also, was it a "sway" from the rear, or a headshake from the front?
..........................................................shitf.............................c3po...................next.victim............................................................
to see some of my ride videos, click the link: http://video.google.com/videosearch?q=b ... oogle.com#
may 2009: my 88 fzr 400 sets a speed record at the maxton mile: http://www.youtube.com/watch?v=GlOk-6aUsKc
haunter
Post by haunter »
swaying on turn in you say?
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
I had hemlet shake from all the wind today. Started around 80mph. Almost unbearable.
megaloxana
shift wrote:your new tires don't happen to be the continental attacks, do they? also, was it a "sway" from the rear, or a headshake from the front?
No they're BT014's. The shake seemed like it was from the front.
'92 FZR 600
haunter
Post by haunter »
it happens on real hard braking
shift
Level 1.5
Level 1.5
Post by shift »
sounds like your body weight was too far back on the bike when it happened. you mentioned you have a dog bone linkage raising your rear up. do you know how much it was raised at the rear axle? what happens is, raising the rear decreases the rake of the front fork, which in turn makes the bike handle faster. it also makes the bike less stable. so you have to find the comfy trade off point.
i would be coming out of turn 17 on virginia international raceway north circuit and get a headshake shifting into 5th and then again at the kink at 14,000 rpm in 6th gear while leaned over. turns out, my body weight was too far back on the bike. i had my r6 shimmed up 4mm at the shock, which translated to 12mm at the rear axle. shifting my weight forward relieved the headshake.
if it doesn't help by shifting your weight more forward, try dropping the forks in the triple clamps a few mm's to get back a bit of fork rake.
megaloxana
I 'll see if I cant move my forks down some more. I'll go take another good ride soon enough and focus on shifting forward to see if that fixes the problem.
Thanks for the tips shift.
ps. where you been? haven't seen ya around in a while.
'92 FZR 600
shift
Level 1.5
Level 1.5
Post by shift »
man, i've been swamped with a new job and i am trying to get back into endurance mountain bike racing -- which takes lots of seat time pedaling. i feel like i don't have time for anything anymore. grrrrr.
good luck with curing the stability issue. let us know how it goes.
ThisEndUp
Level 1.5
Level 1.5
Post by ThisEndUp »
Have you ever set the sag on the bike?
Makes a bit of a difference in handling.
'91 Yamaha FZR600
'09 Aprilia RS 125
'94 Ducati SS/CR 900
'75 Yamaha RD/TD350
'73 Suzuki TR500 Replica
ThisEndUp wrote:Have you ever set the sag on the bike?
THE :hijack:
Talking of which went out this morning for a spin of 50 miles and the new PD valve & springs are fantastic in the fast sweepers and are far more inspiring on tight curves
Mr. Rossi watch out LoL
