Since I first picked her up and gotten her running I've added some LED turn signals on all four corners, wired up the headlight, made brackets for the front tank cover mounts, sawed off those awkward silver brackets and fairing tabs, spray bombed it matte black and wetsanded (still working on that), I got a set of almost new Bridestone Battlax BT014s, I cleaned the crap out of it and got it to my motorsport club's car show just in time. Here are some pictures of how she's sitting now.
Here are my questions:
The airbox is a spiteful, evil old bastard. Getting it on is damn near impossible, once you get it on one side it pops off the other, and won't tighten enough to hold itself down. After two days I ended up ripping the stacks out of the airbox, putting them on each carb independently, then shoved the airbox down on top of them. All the stacks are on well, but the airbox is sort of loose on the stacks because I can't get it down over the lip. I haven't had the chance to ride it in +45 degree weather, so I don't know if it's really causing throttle problems. I was thinking about taking some sticky tack to create a makeshift gasket between the box and stacks as a short term fix. Here's my big question. Whats the best air intake alternative for these bikes? Pods are a bitch to tune from what I hear, even if you make your own stacks. Is there a tried and true method or kit to add pods and jets?
Speaking of that, my carbs were goshdarn impossible to get back into their boots, it probably took my buddy and I an hour and a half, is there an easy way to fix or avoid that next time they come off?
The headlight bracket is ghetto as a mofo. I have zipties helping to hold the light snug at the moment. I was thinking about switching to a fork mount setup with something off ebay, but I have no idea what to do with the gauges. Does anybody have an idea of how to relocate them and get rid of the fairing bracket? I've seen guys do custom metal brackets to relocate gixxer gauges and sell them, does anyone do that for these bikes?
I was thinking about painting the exhaust matte black, thoughts?
What else should I do with her? I'm going to administer a general tune up soon and bleed the brakes, change the oil, flush the coolant, clean the filter and replace the plugs. I'd like to start daily riding, but I'm going to have to work some parking permit trickery to be able to park it on campus and at my apartment.
