STAND STANDS FRONT REAR BANDIT FZR400 FZ1 YZF600
http://cgi.ebay.com/ebaymotors/STAND-ST ... ccessories
well these stands work for a FZR600?
My FZR6 Rebuild
My FZR6 Rebuild
Re: well these stands work for a FZR600?
Yes, they will be fine. My stands are pretty similar to those.
John
John
1994 FZR600R
Actually, no, they won't work well on the FZR600. The stock FZR forks are the problem. The right one is square at the bottom and the left one is more of a pointed shape. They both need to be square to work with the pins on the stands. The pointed fork tends to fall off. I use a rear stand to support the back of the bike and ratchet straps to support the front.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
+5 on that the rear are OK but not as good as using bobbins on the rear the front needs to be the pin type that fits the triple tree an d even for most of those you need the plastics off (I made a longer pin so it cleared the plastics)rotortech wrote:Actually, no, they won't work well on the FZR600. The stock FZR forks are the problem. The right one is square at the bottom and the left one is more of a pointed shape. They both need to be square to work with the pins on the stands. The pointed fork tends to fall off. I use a rear stand to support the back of the bike and ratchet straps to support the front.
Here is a paddock stand rear I made earlier .
http://www.saltmine.org.uk/fzr/paddockstand.html
This is the pin type I mentioned:-
http://www.saltmine.org.uk/fzr/fork.html 9th picture down
Adding a set of Jack bobbins/paddock spools:-
http://www.saltmine.org.uk/kgb/yp7.html
HTH
That's me told then
They will work fine on all of the following bikes:
Yamaha RD350F2
Yamaha TDR250
Yamaha FZR600R (4JH)
Ducati ST4
Honda CBR1000RR6
Honda CBR929RRY
Honda CBR918RRW
Honda VFR800FIW
Kawasaki KR-1S
Honda Dominator
Yamaha RD350F2
Yamaha TDR250
Ducati ST4
Honda CBR1000RR6
Honda CBR929RRY
Honda CBR918RRW
Honda VFR800FIW
Kawasaki KR-1S
Honda Dominator
1994 FZR600R
Yeah, the front forks on these US FZR's are really a bitch. I didn't know the 4JH had different forks. Learn something new everyday.jallen wrote:That's me told then
Yamaha RD350F2
Yamaha TDR250
Ducati ST4
Honda CBR1000RR6
Honda CBR929RRY
Honda CBR918RRW
Honda VFR800FIW
Kawasaki KR-1S
Honda Dominator
Rotortech
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
Yeah, gotta watch that - Brit FZR600R 4JH == US YZF600 4JH, =/= FZR600 3HE...
The FZR600R/YZF600 thing does add a bit of confusion when buying parts as I notice that the US FZR600 is often called an FZR600R and appears to have continued in production well after 1993.
1994 FZR600R
cool thanks for the info, they seemed to be a good price for the pair
My FZR6 Rebuild
My FZR6 Rebuild
