FZR To R6 Brake Swap Q's
ng86
Post by ng86 »
Okay so last night i swapped my old worn brakes for the 02 R6 brake calipers, master cylinder, and lines. Pretty simple if i do say so myself! Minus all the brake bleeding i had to do haha.
Anyway i kinda tried searching around and seeing if anyone else had this problem but couldnt really find too much. Everythings tightened down really well and there are no leaks yet and its been 2 days so i hope im good.
When im riding and i pull the brake lever theres plenty of pressure there (my lever doesnt hit the handlebar or anything) but it seems slightly sluggish slowing down. Im sure i got all the air out even the smallest bubbles, and i tapped the m/c to make sure and bled both calipers. I feel like ive tried everything, this shouldnt be this difficult haha
Im somewhat stumped here! :headscratch:
1992 Fzr 600 - Airtech Tail, K&N Twin Filters, Aftermarket Chopped Exhaust, Custom Blinkers (Lol)
CRG Bar End Mirror, R6 Front MC and Calipers
Soon To Come (aka wish-list) R6 Front Forks, YZF Rear Swingarm, Factory Pro Shift Kit, Stage 3 Jet Kit, and New Emulsion Tubes
ng86
Re: FZR To R6 Brake Swap Q's
Post by ng86 »
I meant to add one more thing, my fzr lines were steel braided so maybe im just not used to the rubber, i dont know.
But they should be interchangeable right? Thanks
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
You should be able to reuse those stainless lines.
One reason it would be sluggish is due to still having air in the lines... make sure that when you do it that all of the air has the ability to rise to the top. I removed my MC from the bike so I could tilt it up properly.
ng86
Post by ng86 »
ragedigital wrote:You should be able to reuse those stainless lines.
When you say removed did you just unbolt it from the handlebar? Thanks
olie05
Level 2.0
Level 2.0
Post by olie05 »
What pads are you using, how old are they, how many time have you stopped with that combination of pad/rotor?
I would redo the bleed and then go out and ride it a few more days and see if it gets better as the pads wear in with the rotors.
ng86
Post by ng86 »
olie05 wrote:What pads are you using, how old are they, how many time have you stopped with that combination of pad/rotor?
Well story goes like this, i actually have an 02 r6 that ive been workin on as well, so i took the brakes off of it and slapped them on the fizz. I had to replace the hose from the reservoir to the mc because it had been cut or somethin. then i continued to bleed them. As far as i know the pads are stock with who knows how many miles.. But today was the first day i rode since i did the swap, maybe 12 miles so far.
I'll take your advice and re-bleed them an keep riding. I was gonna change the pads soon and actually get new rotors theyre kinda worn.
taggy
Level 1.5
Level 1.5
Post by taggy »
another trick to try is to tie the brake lever on (cable tie to the bar) overnight and then try rebleeding, no idea how or why it works but a mate of mine works on bikes and it worked well when I did the lines on mine!
Fzr400 3tj x2
'94 cbr 900rr
ragedigital
4000+ Posts
4000+ Posts
ng86 wrote:When you say removed did you just unbolt it from the handlebar? Thanks
Yep.
taggy wrote:another trick to try is to tie the brake lever on (cable tie to the bar) overnight and then try rebleeding, no idea how or why it works but a mate of mine works on bikes and it worked well when I did the lines on mine!
the idea is to get the lever held in a position where the lines bleed back into the reservois directly not just at the top of the line, when left over night the air in the fluid (that you put there by pouring and may be pumping too fast ) to rise and join with other minute bubbles and get out to the res. not the line where any pumping by you will distribute it again.
As for feeling sluggish on stopping
a} pad wear does not "fit" the new rotors so minimal touching
b} air in the line
c} the rubber line is old and swells with pressure
The pads can be removed and rubbed on sand paper on a flat surface (glass sheet) to get any previous wear pattern warps removed
re-bleed leave over night as described
replace lines with s/steel with the best will in the world nearly 20 year old rubber is NOT upto the cost of your life !!!
rotortech
Level 1.5
Level 1.5
Post by rotortech »
If you have good feel at the brake lever and it is not hitting your grip, then this is not a brake bleeding issue. I think your calipers are gunked up and need to be cleaned.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
ng86
Post by ng86 »
Thanks for the tip! I'll try that this evening.
ng86
Post by ng86 »
I have a feeling it's my pads and calipers, nonetheless Ill pick up some new pads. How would I go about cleaning the calipers?
ng86 wrote:I have a feeling it's my pads and calipers, nonetheless Ill pick up some new pads. How would I go about cleaning the calipers?
VERY carefully any corrosion should be wiped off with nothing courser than old newspaper & brake cleaner liquid, sorry but I recently saw (elsewhere i might add) the pistons being cleaned with emery cloth ehhh! :duh:
kilika2
Post by kilika2 »
I saw a video on YouTube of blue spots being cleaned an put back together. Might try a search there. I would do it but I'm at work and might get in trouble. Haha
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
ng86
Post by ng86 »
Thanks for all the help guys, real lifesavers lol
Locked
