Fresh Gauge Faces
SquadraCorse
Fresh Gauge Faces
Post by SquadraCorse »
Thought you guys might want to see my new Ducati style gauge faces. Couldn't stand the look of the cluttered speedo anymore. I'm working on the lighting now and it's working out well.
blensen
Level 2.5
Level 2.5
Re: Fresh Gauge Faces
Post by blensen »
Very nice! I like it a lot. The lighting idea is good too. How did you do the guage face design?
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Very neat, would be good if you explained how you got the sealed gauges open without breaking the glass .................
trifgeorge
Level 2.0
Level 2.0
Post by trifgeorge »
yamaha_george wrote:Very neat, would be good if you explained how you got the sealed gauges open without breaking the glass .................
What do you mean by sealed? They are not sealed
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
rotortech
Level 1.5
Level 1.5
Post by rotortech »
Squadra,
Nice work here. It would satisfy my curiosity and probably benefit a lot of people if you could write a step-by-step description of how you did this starting with opening up the gauges and where you got the new pretty faces printed up.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
SquadraCorse
I will put together a write up. Unfortunately I didn't take too many pictures at the start but it's all pretty easy, and I can fill the gaps in with some stock internet photos.
SquadraCorse wrote:I will put together a write up. Unfortunately I didn't take too many pictures at the start but it's all pretty easy, and I can fill the gaps in with some stock internet photos.
SC,
I read your blog on how you had the gauges "faked" seems that there could be quite a bit of interest here for them as I for one agree the night visibility is sh**e. The amount of pics is fine (and are very good quality I might add )
May I inquire what it approx. cost to do this ?
TG
the Yamaha gauges I have seen have always been sealed by some kind of waterproof sealant and a flanged over metal rim. are the FZR ones different ?
I must admit that because of this maybe erroneous belief I have not tackled the FZR versions.
SquadraCorse
SC,
TG
Total cost was probably about $40. I had a friend do the artwork in Adobe Illustrator ($0), a sign shop print them out on satin white vinyl with an opaque backing ($25), and the LED lighting was only $12. Some misc. odds and ends (RC car paint for the needle tips, electrical misc. for the lighting, etc.) (maybe $5). So it's real cheap and pretty simple, provided you can get the artwork done or do it yourself. I don't do any graphic design work, only mechanical design and CAD, so that area was a little out of my expertise. You could easily download Adobe Illustrator and work away at it though.
The cluster just has a few screws in the back. Take those out and the whole front fascia comes off.
SquadraCorse wrote:Total cost was probably about $40. I had a friend do the artwork in Adobe Illustrator ($0), a sign shop print them out on satin white vinyl with an opaque backing ($25), and the LED lighting was only $12. Some misc. odds and ends (RC car paint for the needle tips, electrical misc. for the lighting, etc.) (maybe $5). So it's real cheap and pretty simple, provided you can get the artwork done or do it yourself. I don't do any graphic design work, only mechanical design and CAD, so that area was a little out of my expertise. You could easily download Adobe Illustrator and work away at it though.
Thanks for that no chance your pal has that file of the faked panels still?
My CAD is AutoCAD 10 and I have not used that since '95 :-{ my graphic skills are even more ancient i.e.pencil & paper hence my request,
I have no problem paying your man for his file (which given any interest here could be good for his supply of his favourite beer )
Printing is no problem as i have a shop opposite my place, thanks for the tip that the assembly is just a nut & bolt job , the LED's i have in stock from another project (Yellow Peril).
So with art work it would be good to go...........................
trifgeorge
Level 2.0
Level 2.0
TG
YG as SquadraCorse said, unbolt some screws and the face will come off.
R6 pilot seat
KOSO mirrors
H1 HID
jdugen
Post by jdugen »
Like the look! Add me to the list of interested people.
BTW. The stock clock faces are glum at night. I found that the back of the face is sprayed with some semi opaque paint, A dab or three of thinners has it cleaned off and much brighter digits results. BE VERY CAREFUL not to get ANY thinners on the face or you will lose all your numbers!
jdugen wrote:Like the look! Add me to the list of interested people.
Any kind of solvent CAN give problems, the trick I heard was "000" grade steel wool used gently on the rear side made the lights underneath a better chance.
You can also buy LED replacements for bulbs which are a tad brighter too ,without loading the battery / generator down.
Yamster
Donating Member
Donating Member
Post by Yamster »
I had 2 bulbs out on mine when i bought it.Could not get hold of 1.7v bulbs,so changed them all for 3v.Made quite a differance.
Like the look of these though,very nice :thumbsup: .
racerd14666
100+ Posts
100+ Posts
Post by racerd14666 »
uber props for this mod, you just changed my mind on going digital on my stocker fzr but we need some more details here lol
so what did u use for the face plate to lay the art work onto?
how did you get the needles off with out destroying them, cus i got a few old sets laying around and they all seem to be glues on and i just seem top be bending the arm that there mounted to.
you wouldn't happen to have the template for the gauge faces would you?
Yamaha Certified Technician
RDRCR,
Hmm if you had read my GH link the guy on that face mod used a tool like a BRAD Remover or mini crow bar
+5 on the template request :-}
