Specifications
Manufacturer Contour
Optics
Angle of View 135° in 960p and 720p
110° in 1080p and WVGA
Video
HD Resolution Settings: 1080p: 1920x1080 pixels, 30 fps
960p: 1280x960 pixels, 30 fps
720p: 1280x720 pixels, 30 or 60 fps
SD Resolution Settings: 848x480 pixels, 60 fps
Sensor Type: 5 Megapixel Sensor
Video Format: H.264 compression, saved as MOV (.mov) file
Audio
Microphone: Built-in
Compression: AAC Audio Compression
Storage Memory: MicroSD card, up to 32GB capacity
Average Recording Times: 1080p: 15min/GB
960p: 15min/GB
720p: 30min/GB (30 fps), 15min/GB (60 fps)
848x480 WVGA: 60min/GB
Connectors
PC Connection: USB 2.0 (data connection and battery charging)
Power and Battery
Battery Type: Rechargeable Lithium-Ion
Battery Life: Up to 3 hours
Charging: Via USB to computer or included USB Power Adapters
Charge Time: Approximately 4 hours
Additional Information
Body: Water Resistant
Aluminum and Fiberglass
Compatible with TRail Mount System
PC Compatibility: Windows XP, Vista, Windows 7; Mac OS X 10.4 and later
Software: ContourHD Easy Edit™ software
Dimensions (H x W x D): 2.1" x 1.3" x 3.75" (53mm 34mm x 95mm)
Weight: 4.3oz / 123 grams
Operating Temperature: 5°F to 104°F / -15°C to 40°C
Warranty: Contour (formerly Twenty20 VholdR) warranties the ContourHD 1080p for 180 days from the date of purchase of product, unless otherwise indicated by your local government’s warranty laws. The warranty applies only to defects in material and workmanship and not situations caused by impacts or abuse. For complete warranty information, please refer to the Product Information Guide.
The ticket price is $10 and I'm limiting the tickets to 25. You can buy multiple tickets if you'd like. Raffle will close on Dec 24 and winner will be chosen on Christmas. I need at least 20 tickets for the raffle to happen. Money will be due before the close of the raffle. paypal or mailing of a check is fine.
I'm hoping I can have one of the Site Admins or Directors draw the name assuming there will be one that isn't buying a ticket.
I'll update names as people say they want in. Let me know how many tickets.
1 Scott
2 Target30 x 2
3 Mrfreeze5 x4
4 Zero2943
5 Blensen x2
6 Haunter
7 Reelrazor x2
8 Geo x3
9 Kilika2
10 Sweekster x2
11
12
13
14
15
16
17
18
19
20
21
22
