Actually, I'll disagree with you there - you're talking mm of water column in differential pressure - that's LOW. The normal spec is measured in kPa, with the allowable difference between carbs (for the 400) being 1.33 kPa, or 135 mm w.c. The two bottle manometer allows you to quickly and accurately set the carb differential to within 2-3 mm w.c. That's VERY exact, accurate, and repeatable.mrfreeze5 wrote: The 2 bottle method is crude and not very exact, but IMO it beats paying a shop to do it with the right tool.
That's the very reason why - as YG commented - gauge manos ave HUGE errors compared to dP manos, even a very simple rig like the 2 bottle.
