Thundercat Downpipes onto a FZR600R (4JH)
Will a set of downpipes for a YZF600R Thundercat fit a FZR600R (4JH) without any modifications?
1994 FZR600R
Re: Thundercat Downpipes onto a FZR600R (4JH)
for the 3HH no for sure as the pipes need tweeking apart to fit there are older threads on this and I believe it was ThatKid who sold a few Modded sets so you can see what he did.jallen wrote:Will a set of downpipes for a YZF600R Thundercat fit a FZR600R (4JH) without any modifications?
What year is the 4JH as i thought all 600'sFZR were all 3HH here in the UK.
Although I am sure SWEEKSTER will correct me again LoL
It is a 1994 UK model.yamaha_george wrote:for the 3HH no for sure as the pipes need tweeking apart to fit there are older threads on this and I believe it was ThatKid who sold a few Modded sets so you can see what he did.jallen wrote:Will a set of downpipes for a YZF600R Thundercat fit a FZR600R (4JH) without any modifications?
Here is a pic of it when I got it home.
John
1994 FZR600R
Oh a foxeye.
John can you do me a personal favour at some point & tell me what the center distance of the mounting holes for the passanger foot pegs is..
Reason for asking is there is an Urban Legend that says there are alloy foot pegs for the rear that fit the earlier model (they have naff bent tubes) FZR600. I have seen alsorts of model but never found a set that fit
Y_Geo.
Y_Geo.
Trying to avoid doing any work so I popped out to measure for you. The hole centres are pretty much exactly 9cm apart.
1994 FZR600R
It should fit with no problems. The engine between that and Foxeye and the Thundercat are the same except for the charging rotor / stator and the carbs. I don't think Yamaha changed the exhaust system between the two models.
By the way, your bike is a 1995 or 1996 not a 2004. if it is listed as a 2004, then that was the import or registration date.
Corrected the decade. It was first registered in April 1994. The UK 1995 model iirc had more suspension adjustment and came in different colour schemes.cad600 wrote:It should fit with no problems. The engine between that and Foxeye and the Thundercat are the same except for the charging rotor / stator and the carbs. I don't think Yamaha changed the exhaust system between the two models.
John
1994 FZR600R
Thanks. Might get this bike back on the road soonish, seen a new stainless exhaust on ebay for £100 and Motad have got downpipes for £129 which is also a bargain.
More of a project than I was hoping for although it is about as bad as I actually suspected.
1994 FZR600R
John,jallen wrote:Trying to avoid doing any work so I popped out to measure for you. The hole centres are pretty much exactly 9cm apart.
Thanks Now i have to find my notes as to what the old girls is .
i can confirm for definite the Thundercat downpipes and the whole system for that matter fit with no problems as i already have said system on my foxeye
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
R6 lever mountings with short adjustable levers
YZF600R (thundercat) rear adjustable shock
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Bluespot calipers
Wavey front discs
