buckaroo bike
bigginge79
buckaroo bike
Hi guys, i have a fzr 600 95 us model. the bike buckaroos @ 2250 to 2500rpm wot ever gear. The bike had been standing for a year b4 i got it, i soon put a full micron exhaust on (can't remember if buckarooed b4) since the prob i've balanced carbs, checked all jets fuel and air and carbs cleaned needles ect. Didn't do any thing 2 needles or mixture screws (they have bungs in) Not sure wot else could be, Please help. Thanks
FZR 600 genesis, 95 us model
Re: buckaroo bike
B,bigginge79 wrote:Hi guys, i have a fzr 600 95 us model. the bike buckaroos @ 2250 to 2500rpm wot ever gear. The bike had been standing for a year b4 i got it, i soon put a full micron exhaust on (can't remember if buckarooed b4) since the prob i've balanced carbs, checked all jets fuel and air and carbs cleaned needles ect. Didn't do any thing 2 needles or mixture screws (they have bungs in) Not sure wot else could be, Please help. Thanks
welcome aboard nice to have another Brit here.
You say you balanced the carbs do you mean statically or in action with a carb synching tool,
As a matter of interest how are you so sure it is a US model bike
bigginge79
Re: buckaroo bike
thank you. The frame numbers start 3HHE, acording to haynes manual it's US 1995. I balanced carbs using the vacume dial gauges. This did make a differance as the bike only did 120mph b4 balenceing.
Re: buckaroo bike
Ok so may be a set of Euro carbs without the sealed adjustments might be in order?bigginge79 wrote:thank you. The frame numbers start 3HHE, according to Haynes manual it's US 1995. I balanced carbs using the vacuum dial gauges. This did make a difference as the bike only did 120mph b4 balancing.
the bike should be capable of at least 143mph like mine ( santa pods timing about 3 years ago.) & that is as far as I can tell bone stock.
bigginge79
Re: buckaroo bike
in the manual the pilot jets and pilot fuel are diff between US and euro, and lookin into it b4 probs that low in rev range is 2 do with pilot system. ebay it is then, set of carbs. thanks
Re: buckaroo bike
Wouldn't top end be affected a lot by things like sprocket gearing and ride stats we don't know?yamaha_george wrote:Ok so may be a set of Euro carbs without the sealed adjustments might be in order?bigginge79 wrote:thank you. The frame numbers start 3HHE, according to Haynes manual it's US 1995. I balanced carbs using the vacuum dial gauges. This did make a difference as the bike only did 120mph b4 balancing.
bigginge79
Re: buckaroo bike
i'm happy with top end 140 now, it's the lower revs which are the problem
Re: buckaroo bike
I guess my question is, why are you trying to go WFO at just off idle? Why the HELL are you trying to go WFO at 2250rpm in 6th gear ("every gear")?
These are high-revving engines; part of that character is that they carburet like crap off the bottom, and you have to use your left foot to keep them in the proper engine rev range. If you're turning 2250 in 6th, drop two or three gears and feel the magic!
Re: buckaroo bike
+1. If it seems to run perfectly now after carb cleaning and syncing above three thousand rpm, then I say just keep it above there. If your rpm's are dipping that low, it's probably time to change gear.DonTZ125 wrote:I guess my question is, why are you trying to go WFO at just off idle? Why the HELL are you trying to go WFO at 2250rpm in 6th gear ("every gear")?
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: buckaroo bike
yeah so your bike must really "buckaroo" alot for you to complain aboutit right? you dont need to replace your carbs to get past those covers to the idle screws you know. just carefully drill throu them then you can tweek them and have the bike running perfect foryou
thatkid
Re: buckaroo bike
apsolus wrote:you dont need to replace your carbs to get past those covers to the idle screws you know. just carefully drill throu them then you can tweek them and have the bike running perfect foryou
They are tamper proof plugs (bungs) get them outa there, also I have a raped set of UK carbs (for spares), if the Jets you require match UK specs (I think they will) give me a shout. I'm talking postage and packing + £1 to cover paypal fees e.t.c.
Mal.
bigginge79
Re: buckaroo bike
thanks for help, goin a have a play with mixer screws, when stops raining. when i put buckaroos in every gear, this was just a trial. i mostly happens in 1st sittin at 5mph (slow traffic)
Re: buckaroo bike
hows your chain and sprockets if there worn and loose it can affect your herky jerky also
thatkid
Re: buckaroo bike
haro504 wrote:hows your chain and sprockets if there worn and loose it can affect your herky jerky also
Defiantly will/does
bigginge79
Re: buckaroo bike
haven't had chance 2 try any thing yet. but brother in law has just brought same bike so goin 2 swap carbs over see if any change. some 1 at work said could be crack in valve has only does at low revs, possible?????????
