RIM CHOICES FOR 90 FZR 400
Re: RIM CHOICES FOR 90 FZR 400
Anyone know of wire wheels that would bolt on??
gogofizzpow
- Level 1.5
- Location: Europe, California, Georgia, Belgium (yes, this is not part of the 1st one)
I think Yamaha George knows something about the wire wheels, but I dont know about direct bolt on...
'96 FZR600
-Stainless brake lines, K&N Filter Pods, R6 front calipers, R6 Front and rear Master cylinder, Factory Pro Stg 1 Jetkit, R6 Headers (TK), '08 R6 Rear shock w/ adjustable dogbones (RR), Airtech R1 kit (and all the mods that go with that), Home made 5 d ignition advance, YZF600r D&D Modified short can with R6 mid pipe, Progressive rate front suspension, YZF600r Swingarm/wheel, 520 14/45, 47, 48 Sprockets, China's rearsets, YZF600r modified undertray, Cheap battery mod so I can run lay flat glass matts, And anything else I become compulsive enough to do to her...
-FOR SALE- *sniff sniff*
If you use wire wheels on the FZR, they need to be 22" Gold Wire Wheels and the seat cover needs to be Leopard skin.... ha!
I don't think it would be a good look. YG has some on some vintage bikes and they look fine.
gogofizzpow
- Level 1.5
I think you have it wrong though.. the cheetah print goes a little better... YG's bike is a vintage though correct...
'96 FZR600
GFP,gogofizzpow wrote:I think you have it wrong though.. the cheetah print goes a little better... YG's bike is a vintage though correct...
no that is wrong actually it is Y-G who is vintage, the bikes are classic (ie not old enough for vintage yet!)
thatkid
That's a classicyamaha_george wrote: GFP,
gogofizzpow
- Level 1.5
touche...
'96 FZR600
As long as you don't mind doing some modification to the wheel or swinger, Gixxer and CBR600 wheels can be made to fit. Thus, a swingarm swap would not be necessary.
