Thanks,
Hi,mawler wrote:Tyres that are out of balance can cause premature wear of wheel & steering bearings, maybe fork bushings/seals, and uneven wear on the tyres themselves. Get the front end up, spin the wheel and check for any obvious run out on the wheel and tyre, and for any play in the wheel bearing, same applies to the rear wheel, then get both front and rear wheels balanced.
pefrey wrote:I'd check the front end balance. Take the wheel off, put the axle through and put either end of the axle on a jack stand. Spin the wheel. If the same spot ends up at "6 o'clock" after 3 or more tries, it's out of balance. You can balance it yourself using this method. The higher the number of times you spin it, the more accurate you will be in identifying the "heavy spot".
smokinbunta wrote:so...question here... whenever im goin between 45-55 my front end shakes like CRAZY! speed wobble crazy so..say i let go of my handle bars at 55 and as it decelerates, it shakes more and more, but if i can make it below 45 it stops completely, or if i let go any faster then 55 it wont shake till it gets down to 55..im pretty stumped on this...not that i just sit there and just let go of my bars all the time...but i spend alot of time in that speed range around town and i can feel it pretty good in my hands...feels like im gettin arm pump and im not even on a dirtbike...any ideas??
Thanks,
yamaha_george wrote:smokinbunta wrote:so...question here... whenever im goin between 45-55 my front end shakes like CRAZY! speed wobble crazy so..say i let go of my handle bars at 55 and as it decelerates, it shakes more and more, but if i can make it below 45 it stops completely, or if i let go any faster then 55 it wont shake till it gets down to 55..im pretty stumped on this...not that i just sit there and just let go of my bars all the time...but i spend alot of time in that speed range around town and i can feel it pretty good in my hands...feels like im gettin arm pump and im not even on a dirtbike...any ideas??
Thanks,
Did you get what was causing this sorted?
