Front turn signals (Flush versus long stem)
I notice some FZR's have the nice looking flush mounted front turn signals that integrate nicely rignt into the cowling but cant find that on the Yamaha microfiche. Microfiche only shows the long stem ones that stick out through the hole. Is this a stock or aftermarket item?? Where can I get these flushies?
Re: Front turn signals (Flush versus long stem)
Aftermarket = Ebay. Make sure you get dual filaments for the front: 3 wire.
'92 FZR600
Lots of Powder
Lots of Powder
- trifgeorge
- Level 2.0
i know that i'm a noob, but why dual filament?
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
R6 pilot seat
KOSO mirrors
H1 HID
Dual filament bulbs (3 wire) allow you to use the front signals as running lights as well as blinkers. I believe there is also a mod that can be done to make the 2 wire, single filament bulbs work for this.
+1 Yes there is. pm me for info.4Rings6Stars wrote:Dual filament bulbs (3 wire) allow you to use the front signals as running lights as well as blinkers. I believe there is also a mod that can be done to make the 2 wire, single filament bulbs work for this.
My FZR6 Rebuild
My FZR6 Rebuild
- trifgeorge
- Level 2.0
Got it!:D thank for the answer4Rings6Stars wrote:Dual filament bulbs (3 wire) allow you to use the front signals as running lights as well as blinkers. I believe there is also a mod that can be done to make the 2 wire, single filament bulbs work for this.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
The only company, that I know of, that makes the pefect fitting flush mount turn signals is Flanders.
Look on page 76 - center bottom (white):
http://www.flandersco.com/Images/PDF/El ... atalog.pdf
