Please help me with this .....bike. I have taken the carbs off about 6 times and I'm lost. Thanks
I've slapped on a 110 Main Jet ,needle is at the 2nd position , carb floats at 23mm and idle screws at about 2 1/2 turns out. The kit is a Factory Pro and I still have the stock emulsion tubes with 13k miles on them(They don't look that bad..I've ordered some from Factory Pro but it is taking forever) . Stock 52.5 starter jet.
I am currently having issues with idling right and after checking header temps with an Infra Red gun at IDLE , #1,2, and 4 are around 350-400F degrees . #3 is only 170. Seems that the Idle Screw does not help . I have allmost turned it back in(screwed in from 2 1/2 turns)
Is it the float height for carb #3? Too rich?
Not firing properly? Too weak of a spark?
P.S Have changed the Voltage Regulator because it wasn't putting out 13.7-14V at 3000 Rpms.
Have synched/cleaned the carbs
Spark Plugs do not look that bad and only have about 1500 miles on them. Have also cleaned them.
Have checked for spark for all 4 wires. Seems ok.
What is the screw do in this picture? Also is the Starter Jet just for starting?
What about #33. The Pilot Air Jet(132.5) What is this do and how to adjust?
Note: Do not take credit for the pics. Just borrowed them and will delete if necessary. Thanks
