So, my clutch was slipping in 3,4,5 gear so, I installed a new clutch since I just bought the bike. I've put it all back together but now my clutch won't engage.
I haven't done one in years but I don't feel like I'm doing anything different. I heard a noise while tightening up one of the springs but it still snugs up to 4-5 ft lbs. If I did snap the thread inside would this be the result ?
thanks
clutch isn't working
Re: clutch isn't working
OK If I heard a noise I would have that clutch back down so quick it would not be funny.noise could have been a clutch spring boss sheering oops lots of lovely metal bits flying round ask on the board about what some one found on the oil screen and asked us to identify .......................ludikris wrote:So, my clutch was slipping in 3,4,5 gear so, I installed a new clutch since I just bought the bike. I've put it all back together but now my clutch won't engage.
thanks
Did you put all the steels facing the same direction,
have you adjusted the cable properly ie in the right order,
have you checked that the tiny ball bearing did not fall out whilst you played with the clutch
Have you adjusted the clutch set screw
pulling it out.... will let you know..
Cool but after wednesday I am away from the desk till then, gone RIDING yee Haaludikris wrote:pulling it out.... will let you know..
paulmartin483
You have not pushed down the clutch pedal. You would find the master cylinder in dead mode. I was thought that You will change the master cylinder and slave cylinder. It would be good for your bike.
The biggest cause of malfunctioning Yamaha clutches (after rebuild) that I've seen is the alignment of the pressure plate - it goes on 4-6 ways, depending on the model, but only ONE is correct. There are match marks on the plate and hub that must line up (a dot and triangle). If they aren't aligned, the clutch doesn't bite.
There's neither on an FZR600.....paulmartin483 wrote:ludikris wrote:pulling it out.... will let you know..
'92 FZR600
Lots of Powder
Lots of Powder
PM483
This is a 600 which has a cable actuated clutch!
if as you say the lever was dead on a hydraulic system I would look to bleeding the system of air not scrap the system!
alright so it turns out I didn't line up the pressure plate correctly as described above and inturn I broke the pressure plate
luckily, the piece the spring puts pressure on broke clean off and nothing was floating around in the oil..
looks like a cheap fix too since the pressure plate is only $20 off bike bandit..
Thanks guys..
Thanks guys..
