Hi guys, it’s been a little while since I was last on, been busy with my bike club.
I am getting some gear box noise. Symptoms are a bearing noise which is noticeable at idle in neutral and decreases with the clutch pull in.
I have replaced the clutch basket needle roller bearing thinking that may be the culprit but this has not helped. The noise does not effect
clutch operation or gear changes.
Wondering if anyone has a similar problem and knows the possible cause?
Gearbox noise
Re: Gearbox noise
FZR's are NOT renown for being quiet running engines.
BUT saying that you are right to take listen use a mechanics stethascope or a very long handled screwdriver pressed to the base of the ear / jaw line to localize the noise.
Re: Gearbox noise
is it a rattle or a whirr?buzzawak wrote:Hi guys, it’s been a little while since I was last on, been busy with my bike club.
if it a rattle check the clutch basket look at the teeth on the basket have they any grooves on there they should be smooth , if its a whirr i would go with the clutch release bearing
If all else fails (hit it with a big hammer)
Re: Gearbox noise
Its a whirr sound.FZR AL wrote:is it a rattle or a whirr?buzzawak wrote:Hi guys, it’s been a little while since I was last on, been busy with my bike club.
I dont think the 400 has a clutch release bearing?
The clutch push rod spins on a single steel ball.
paulmartin483
Re: Gearbox noise
I was thought that There was gear warn in the transmission. So You have required to change the gear box kid. It would be great for you. I wish that You will find nice gear box.
Re: Gearbox noise
LOL. Just part it out and buy another.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Gearbox noise
Yup the advice our friend has given,must be a lot of spare parts where he is everything is throw it away & get anew onedelvryboy wrote:LOL. Just part it out and buy another.
