foot peg problem with YZF600R swingarm swap
abs929cbrrr
Post by abs929cbrrr »
i totaly forgot the swingarm will not clear the stock foot pegs. does anyone know how much i need to have them machined down? not sure if aftermarket rear sets will solve this problem but anyone knowing anything please let me know asap. i am doing to the machine shop friday to finish my rear end swap mod.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
cad600
Re: foot peg problem with YZF600R swingarm swap
Post by cad600 »
I'm cutting the mounts off and will have new ones welded onto the frame so they sit out far enough. I'm going with 1/2" thick steel and will cut the bolt down and drill it so I can put a retaining pin through it. Help any?
abs929cbrrr
yeah that makes sense. i did some quick measuring and it looks like it i cut them down 0.500" (the peice that mounts to the peg) it should clear. the YZF600r measurement is about 9.750" wide and the FZR600 peg distance is 9.000". i dont really feel like cutting these off right now since i am not close to a welder and the bike is my daily driver right now. over winter i am up for that thought.
ill see if my quick fix helps. i dont feel like spendin a ton for rear sets
cad600
Post by cad600 »
I would agree with you. The only nice part about doing it this way is that I can use any aftermarket rearset I want to. Since I drilled and tapped my own mounts. I've found the Gixxer rearsets are on ebay quite often and relativly cheap. The only difficult part is finding ones that have the same shift linkage type.
abs929cbrrr
cad600 wrote:The only difficult part is finding ones that have the same shift linkage type.
thats easy, i will be using this style: i am buying stock ones though, i am not comfortable with non-pivoting pegs for the street. also i really like these rear gsxr's anyway...from the looks of it all i need is spacer plate made and then i can move the pegs back 1 inch and up and inch anyway like i want so my foot peg problem is sloved!...ill be talking mod king soon again it seem.
01-03 gsxr 600
00-03 gsxr 750
01-020 gsxr 1000
kingcobra
Post by kingcobra »
can't you just use spacers behind the peg brackets and the heel guard? just a guess here...
my bikes
abs929cbrrr
i can but it throws off the rear brake master cylinder. i am going to machine them down .500" per side to get me by right now. i will be upgrading to new style rear sets thought.
nynoah
Post by nynoah »
just put some washers behind the rear sets, shave down the rear of them at an angle and you will clear just fine.
abs929cbrrr
i think ill clear, i machined them down .500 from the backside. they were .750 thick. that just gained me an inch until i can aford gsxr rear sets....which might be never!
mszilves
Level 1.5
Level 1.5
Post by mszilves »
abs600fzrr wrote:i think ill clear, i machined them down .500 from the backside. they were .750 thick. that just gained me an inch until i can aford gsxr rear sets....which might be never!
abs can you post some pics of what you did? I've got a YZF swinger/wheel coming next week, and will likely need to do this as well. thanks
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
NHFZR600
Level 2.5
Level 2.5
Post by NHFZR600 »
http://s78.photobucket.com/albums/j111/ ... zer%20600/
check out the pics of my rearsets to get some ideas. they are the sets off of a YZF. they fit great. have to weld a nut onto the outside of the bracket to hold the bottom on because if you go straight thru on the bottom the chain will rub it. B
Leftover 07 Silver Ninja ZX6-R
**SOLD**
1990 FZR 600 Satin Black / Metallic Black Frame / Metallic Copper wheels
- Mods -V&H PIPE & HEADERS - 1999 R6 TAIL - 2001 UNDERTAIL - INTEGRATED LED TAIL LIGHTS - 2000 YZF TANK - 1995 YZF FRONT SUSPENSION AND GUAGES - MICHELIN PILOT POWER 120/60 ZR 17 - 1995 YZF REAR SWING ARM AND WHEEL W/HUGGER - METZLER ROADTEC Z6 170/60 ZR 17 - Xentec 8000K HID HEADLIGHTS - WHITE LED LIGHTING KIT
95FZR600
Post by 95FZR600 »
Pics would be good abs
abs929cbrrr
pic of what did..machined them down about .500" per side on the back, also had to mill the screws down .375" to hold the footpegs on and retapped the bolts.
700 miles so far and no problems...just look like hell since i ride alot.
PIMPMYFZR
Post by PIMPMYFZR »
Abs . Do you got the yzf swingarm on your bike?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
abs929cbrrr
not yet, my bearings didnt come in for that yet so as soon as they come in ill throw the rear end on.
