Carb Tool
yamaboy
Level 1.5
Level 1.5
Carb Tool
Post by yamaboy »
Hello everyone,
So I tore my carbs apart and I was disgusted. One of the jet screws was busted , 2 of the carb screws were stripped and also one of the float needles was the wrong kind ..Also missing the small bent wire.
I've managed to make a carb synch tool . Here is a pic for those visual learners.
Enjoy
Carb Tool
Welding Tips
Wrong Float Needle..One on the right
Busted Jet Screw + Stock Needle
Carb Internals(for future reference i guess)
Starter Jet + Choke Slider
Emulsion Tube
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
DonTZ125
Moderator
Re: Carb Tool
Post by DonTZ125 »
STOP - That is NOT where the MIG tips and balance bottle tubing goes! That is the drain screw for your bowls, and has exactly nothing to do with synchronizing your carbs. On each of the rubber boots bolted to the head, into which the carbs are socketed, there is a M6 Phillips screw with a copper gasket. THAT is your balance port. Remove the screw, insert the MIG tip, attach the tubing. Replace the screws when finished, or else you'll have a truly nuclear air leak.
Re: Carb Tool
Post by sweekster »
DonTZ125 wrote:STOP - That is NOT where the MIG tips and balance bottle tubing goes! That is the drain screw for your bowls, and has exactly nothing to do with synchronizing your carbs. On each of the rubber boots bolted to the head, into which the carbs are socketed, there is a M6 Phillips screw with a copper gasket. THAT is your balance port. Remove the screw, insert the MIG tip, attach the tubing. Replace the screws when finished, or else you'll have a truly nuclear air leak.
Agreed
Uh...what he said.
trifgeorge
Level 2.0
Level 2.0
Re: Carb Tool
Post by trifgeorge »
I agree 2!!!
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
yamaboy
Level 1.5
Level 1.5
Re: Carb Tool
Post by yamaboy »
Ha ha , wow! I wasn't really sure about that so I just assumed that it goes in there. Thanks for shining some light on me and preventing me from doing something dumb. :duh:
P.S I removed the pic so it doesn't confuse anyone.
unreal3z
Re: Carb Tool
Post by unreal3z »
Is there a specific length that the clear tube going to the carbs has to be cut to? Also what type of oil do you use? And finally does the the tube going between the two bottles get completely submerged in the oil?
DonTZ125
Moderator
Re: Carb Tool
Post by DonTZ125 »
As long as it needs to be.
Some use ATF, some use 2-stroke oil. I used tap water and a quick thumb on the kill switch! :banana:
You betcha...
Re: Carb Tool
Yammaboy,
PLEASE add you pics & captions to the how-to:- in the wiki called all you need to know about carbs & the sync tool how to with your pics of the tool you made & the mig jets
Thank You
Y-Geo
yamaboy
Level 1.5
Level 1.5
Re: Carb Tool
Post by yamaboy »
yamaha_george wrote:Yammaboy,
Thank You
Y-Geo
YG
I tried to figure out how to post 2 small pictures which enlarge once you click on them under (Syncing ,wiki : all you need to know about carbs) ..but I failed. I completely forgot html code . I can give you the photobuket image code or html code if it helps. I hope ragedigital shines some light so we can figure this out. :shocker
