r1 conversion body kit
hey i have a r1 body kit and im looking to change out the single head light to a projector light or something with a lil bit more style googled for a replacement but not to much luck the hole is a 4'' round let me know if any one has any ideas thanks
rocket till the wheels fall off
gogofizzpow
- Level 1.5
- Location: Europe, California, Georgia, Belgium (yes, this is not part of the 1st one)
Re: r1 conversion body kit
have you thought about using the housing piece from 07 r6 or similar body series. looks like a bmw projector with a lower current draw
'96 FZR600
-Stainless brake lines, K&N Filter Pods, R6 front calipers, R6 Front and rear Master cylinder, Factory Pro Stg 1 Jetkit, R6 Headers (TK), '08 R6 Rear shock w/ adjustable dogbones (RR), Airtech R1 kit (and all the mods that go with that), Home made 5 d ignition advance, YZF600r D&D Modified short can with R6 mid pipe, Progressive rate front suspension, YZF600r Swingarm/wheel, 520 14/45, 47, 48 Sprockets, China's rearsets, YZF600r modified undertray, Cheap battery mod so I can run lay flat glass matts, And anything else I become compulsive enough to do to her...
-FOR SALE- *sniff sniff*
As far as I know, no one has really modded the airtech kit for a better headlight. You are going to have to design something to fit in the space from scratch.
Upgrades:
- Fizzinatorr
- Level 6.5
I have a headlight which should work for you pm me
well i have a body kit iv been working on its the r1 kit from online ( bought the bike with it not my first choice) but im doing all this for my room mate he wants some kind of upgraded (if you will) head light something with a bit more style than stock. i was thinking some kind of projection head light just b/c of the style of the bulb housing. i really dont know if the bike can even handle this kind of upgrade just b/c its a old bike it may or may not be able to power it. let me know what you all think about this
