06-07 R6 Voltage Regulator
gre3nskeeper
Post by gre3nskeeper »
Does anyone have any experience with using a 06-07 voltage regulator in-place of the 95+ fzr reg? From the wiring diagrams i'v looked over, both use the same pin-out setup: three ac on the bottom row then a positive and ground on the top rows.
Just want to verify that the voltages are the same.
1995 YZR600R
M in KC
Level 2.0
Level 2.0
Re: 06-07 R6 Voltage Regulator
Post by M in KC »
Won't know why not they are just a devise to dissapate heat. Although the '95 style maybe easier to fit fully insulated spade connectors to than the '06-'07. It looks like they beefed up the cooling fins and changed the wire harness mount on the '06-'07 is all from the '95.
Post by sweekster »
I read somewhere the the top center pin on the 06+ was a dead pin. Don't know how much truth there is to that though.
gre3nskeeper
sweekster wrote:I read somewhere the the top center pin on the 06+ was a dead pin. Don't know how much truth there is to that though.
yes the top center is a dead pin according to the 07 service manual.
My question is will they regulate voltage the same?
1995 YZR600R
Simple answer is YES and the proof is http://www.saltmine.org.uk/fzr/vr.html
gre3nskeeper
Confirmed. wired it up today and took it for a 30 mile ride. Recharged the battery fine.
1995 YZR600R
gre3nskeeper wrote:Confirmed. wired it up today and took it for a 30 mile ride. Recharged the battery fine.
PLEASE read "before George Kills you " thread !!!
