Um, how easy is it to get new valve retaining cotters/collars?
My home-made valve spring removal tool wasn't as stable as I thought, and I've ended up with a couple of pingfuckits
is it the same part number for all FZR400s?
1WG-12118-00-00? (mine's a 3EN2 model)
a
valve cotters?
valve cotters?
When a passenger of the foot, hooves in sight, tootel the horn trumpet melodiously
http://www.kickingtyres.com
Re: valve cotters?
You should be able to order them through any dealer - online or otherwise.
http://www.bikebandit.com/houseofmotorc ... 0w/o/m7218
Re: valve cotters?
If there what hold the valves in,i have just stripped a 3HE head so have got loads if you get stuck.
I am presuming they will be the same size
Re: valve cotters?
LOL I don't know what a "pingfuckit" is but I'm going to use that term in the future. I imagine it's from the sound a small spring or part makes as it launches from your control. Is it the sound it makes when it launches or when is lands somewhere? LOLfeef wrote: and I've ended up with a couple of pingfuckits
