Fuel shut off.
kilika2
Fuel shut off.
Post by kilika2 »
Just curious as to how long it takes everyone else's line and pump to run out of fuel after you shut off the petcock.
I winterized my bike and when I was done letting it warm up the other day I shut off the pc and let it run another 5 mins or so. It never died. Did I just not wait long enough?
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
Re: Fuel shut off.
kilika2 wrote:Just curious as to how long it takes everyone else's line and pump to run out of fuel after you shut off the petcock.
Chris at idle the bike is fairly economical on fuel mine was almost ten minutes.
That or you turned the bike to reserve ?
kilika2
Re: Fuel shut off.
Post by kilika2 »
I kind of figured that. Since I get about 46 mpg out of it, I thought maybe I didn't let it go long enough. But I double checked to make sure I didn't go to reserve. Thanks George.
2006 R1 Sold :-\
WSM
Level 2.0
Level 2.0
Re: Fuel shut off.
Post by WSM »
Yeah, mine ran for an easy ten minutes.
1998 FZR600
All Original, except for a custom saddlebag set up. A machine shop buddy of mine seamlessly fitted two GS bags on the rear end for last summers ride.
30,000+ odo
JRK5892
Level 1.5
Level 1.5
Re: Fuel shut off.
Post by JRK5892 »
i have always been told you never want to run it dry... on all 8 of my bikes ranging from choppers, to metrics and harleys, i have just started them for about 10 min every 2 weeks and they are good, without any gas in the carbs the gaskets and seals, and o rings will dry up and get brittle and crack... you will have to rebuild the carbs, little bit of stabil and start it every now and then and your good bud
http://www.thepowderpro.com
The Powder Pro
custom powder coating, polishing, paint, bike builds, and more
kilika2
Re: Fuel shut off.
Post by kilika2 »
I put stabil in there, and then looked at the wiki for ways to winterize the bike. The process that I am doing is what I came across. I kind of thought the same thing about the orings and what not. But then again I am thinking about taking the carbs apart and cleaning them anyway. Maybe this will just motivate me. I also hit a snag when I let it sit a week the battery drained to 8.5v. So now I have the batt unhooked until I get a battery tender.
2006 R1 Sold :-\
