swinger swap question
hey there guys I was just curious as to why everybody cuts the frame instead of just cutting the swinger and having spacers made to use the fzr bolt that way you always have a choice to go back to factory swinger if ever you need be.is there pluses and minuses i'd like to know please if you guys could help that would be great thanks in advance, Hilly
90 3tj fzr 400 /91 fzr 600 engine, 639 wisco big bore,racing cams,13:1 compresion, heavey duty clutch, k@n twin pods,stage 3 jets, full muzzy exaust, r6 rectifier,all 600 electronics,600 rad,showa front forks,yzf 600 gas tank,steel braided lines,brembo rear brakes and factory 400 front, 04 r6 front and tail,01 r6 sides and lowers, and soon 520 con
86 fzr 250 exup bone stock
Re: swinger swap question
hey guys sorry i did not mention its a r6 (99-02) swinger and anytime i see a swap they always cut the frame out on the fzr instead of cutting the swinger thanks again
you can only really cut the swingarm down so much and then you have to grind the frame to fit it in
thanks alot guys it would definatley make more sense to only cut one down rather than both and i appreciate the quick responses, cheers
