Hey guys i have just put a r6 reg on my FZR as the old 1 seems to not be working.
I have wired it up like this post
http://fzronline.com/wiki/doku.php?id=r ... conversion
and it still does not charge, it only puts out 1 volt.
I have tested the stator and seemed to test fine checked all wiring.
I am at a loss as where to go from here
Any ideas?
Also if any1 needs the plug for a R6 reg i can get them i can also get the 8 pin plug for the igniton all new with pins,
just Pm me if you want 1
sh0rty77
Charging
Re: Charging
Hi,sh0rty77 wrote:Hey guys i have just put a r6 reg on my FZR as the old 1 seems to not be working.
Any ideas?
sh0rty77
Yesterday I put the "trouble shooting your charging system / V-R" Flow chart in the two WIKI's.
You just might want to read that thro and follow its advice.
http://fzronline.com/wiki/doku.php Bottom of the page 3rd item if I remember correctly.
Re: Charging
Already have.
But i guess ill do it again.
FZR600 10/90
Single Headlight
Single seat
Working progress
Single Headlight
Single seat
Working progress
- kilika2
- 1000+ Posts
Re: Charging
Also, reelrazor told me once to make sure that the ground was secure and it would be a wise idea to run a 10 gauge wire from the VR all the way to the main engine ground buss.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Re: Charging
Should the bike still run after disconecting the battery??
This is why im thinking that it is not charging because my bike stalls.
A car will run without the battery connected and i presumed that a bike would be the same, am i wrong??
I went a brought a new digital multi meter and tested everything as the VR trouble shooting flow chart.
get 14.1 volts at 3000rpm so going by the chart its charging.
get 48.9ac volts on all pins
and .32ohms
and .32ohms
FZR600 10/90
Single Headlight
Single seat
Working progress
Single Headlight
Single seat
Working progress
Re: Charging
Sorry Shorty not been exactly on the 1 for the last 2 days or so.sh0rty77 wrote: get 14.1 volts at 3000rpm so going by the chart its charging.
and .32ohms
Those figures look ok, as for the bike continueing to run yes it should BUT i would recommend against pumping juice into thin air for the sake of the alternator & the VR they are both meant to work with load.
Re: Charging
Thanks mate i will leave it as is for now and just see if the battery goes flat.
FZR600 10/90
Single Headlight
Single seat
Working progress
Single Headlight
Single seat
Working progress
