Have not posted in a while, Have been very busy, new job, 2 year old. I had cleaned the carbs, disassemble and dipped. sync with a cheap pro carb sync 99.00 ebay; it kinda sucked. Well I picked up a vacuum gauge set for 60.00 ebay. It works much better.
I started off with a stumble around 5000rpm to 6500rpm, tuned the carbs again and now I have a stumble around 1000rpm to 1500rpm. So when taking of in first gear can make it interesting, not such a smooth take off.
Any ideas? I'm going to re-sync again. I'm think about just buying a used set of carbs if I can't get it right. I just can't imagine taking it to a stealer.
Chasing the carb
Chasing the carb
FZR 600 91 D&D
Re: Chasing the carb
Jet kit installed? Is your D&D a pipe or full system?
Slip-on I believe it is a stage one kit. It ran fine before the carb cleaning.
FZR 600 91 D&D
back out the A/F screws .5 turns out and see if that helps
http://www.factorypro.com/
Look up CV carb tuning for High RPM engines.
1.Product /tech support
2. Motorcycle Tuning tech
3. CV carb .....
4. High RPM Engines
Hope this helps...
3. CV carb .....
4. High RPM Engines
Hope this helps...
I'd remove the jets and re-clean them again. Sometimes a little bit of carb cleaner solidifies before you can get them clean. This may not be the case, but it can't hurt to do it.
