Wiring
Fizzinatorr
Level 6.5
Level 6.5
Wiring
Post by Fizzinatorr »
what does the wire on the left go to? I know the right is the servo
haunter
Re: Wiring
Post by haunter »
if I had to guess I would say sidestand?
but there is a neutral switch assembly in the parts fiche with a similar looking plug.....
I can take a peek tonight maybe and see where mine goes
Re: Wiring
Fizzinatorr wrote:Image
Ik's are not my forte, but the wiring looks original, I would look at the colour scheme of the physical wires and then hunt thro the wiring diagram for those colours
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
if anyone can trace that wire i would be very appreciative
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
to add to the mystery....
the new fuel pump is installed and works great. but i don't think i am getting any spark. the bike just turns over and over and over but nothing happens
Re: Wiring
Post by sweekster »
I don't know much about 1k's but that sounds like your pickup coil? Does that 1k have one? I know that they have an actual alternator as opposed to stator? I might not be much help..
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
okay checked somethings out, battery is def. good, not the clutch switch, not the sidestand switch
i believe this leaves: plugs, plug wires, pick up coil, the digital ignitor
haunter
Re: Wiring
Post by haunter »
figure that plug out yet?
billy_awesome
Level 2.0
Level 2.0
Re: Wiring
Post by billy_awesome »
How do you know your not getting spark?
Take a plug wire out and get a old plug and put it in the plug. Try starting the bike and see if there is spark on the plug.
If no. Check:
-coils, pickup coil (located in your stator cover) and your CDI (computer, brain)
I wish I could be more help to what plug that is for, but the 1k's are different than the 600's
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
i don't have any old plugs :/ this is a brand new to me bike, i have one from the fzr 600 though - will it work?
also no haunter, i can't figure out what that plug is...checked the schematics
haunter
Re: Wiring
Post by haunter »
damnit.
with my sidecover on and battery in, at teh parking lot here at work
I can't find anything like that.....besides the fuel pump
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
argh! thanks for trying to check, i appreciate it...it could be the source of my seemingly no spark
haunter
Re: Wiring
Post by haunter »
if nothing else I should be able to take stuff out this weekend....no idea how late ill be working all week banghead
sucks kinda......but comptime and OT pay are nice.
Fizzinatorr
Level 6.5
Level 6.5
Re: Wiring
okay....very very weak spark, tried it with a 600 plug
i found this: "PROBLEM FREAKIN SOLVED
Man, after lots and lots of testing, working through the harness etc, I finally figured out why I had no spark.
Drum roll please.
When you read the schematic it show "kick stand relay" or the relay that grounds the ignition box to prevent the bike from starting if it is in gear, clutch, side stand. Well I assumed that when the relay was powered, it would close and tie the ECU to ground. Well, the relay is the opposite. When there is no power, it is continuous and ties the ECU to ground. When voltage is applied, it opens the circuit, then the ECU will provide spark.
Just cut this stupid wire, and now all spark plugs are blazing away with tons of spark.
Well, at least I learned a lot about trouble shooting electronics."
could that be my mystery wire?
haunter
Re: Wiring
Post by haunter »
um...it could be.......no idea though......I'll try and find that part of teh harness this weekend
glad to know its better though!!
