Features:
If you’re a fan of down-insulation and cozy raschel fleece, this is the one for you. Designed with 550 fill down and quilted side panels on the exterior, this jacket unzips to reveal a cozy, high-loft fleece lining on the interior that keeps you extra warm in freezing weather.
High-loft, cozy fleece liner
Brushed chinguard lining
Internal media pocket
Stretch, quilted side panels
Two hand pockets
Key clip in hand pocket
North Face Apex Bionic Thermal Brown XL Retail $180 $120 Shipped
The North Face's most versatile utility soft shell, the women's Apex Bionic Thermal Jacket takes the classic to the next level with a high-loft fleece backer for added warmth. The outstanding Apex ClimateBlock wind-blocking exterior is complemented with weather blocking stretch woven cuff and hem cinchcord.
• Fabric: 75D 471 g/m2 (13.9 oz/yd2) polyester woven face and raschel back Apex ClimateBlock with DWR
• Apex ClimateBlock technology blocks wind, gives exceptional stretch mobility, and is breathable
• Wind permeability rated at 0 CFM
• High-loft fleece backer for increased warmth
• Two hand pockets offer convenient gear stashing
• Stretch woven cuffs close wrist gap for added warmth
• Hem cinchcord blocks out weather and traps core warmth
• Standard fit provides superior comfort
• Center back length 25.5"
• Weight: 28.6 oz. (810 g.)
Marmot Women's Tamarack Jacket Color: Red/White Size: S Retail $200 $120 Shipped
Lighter weight than your traditional ski jacket, Marmot's Tamarack Jacket for Women is built with Marmot Membrain® fabric, making it just as waterproof and breathable. While the Tamarack has reduced bulk, it hasn't lost the features of ski jacket, PitZips™, powder skirt, laser drilled sleeve and chest pockets, handwarmer pockets, draw cord hem, and a DriClime® lined collar. And for added versatility, the Tamarack has zip off hood and is Zippin™ compatible.
• Marmot MemBrain® waterproof/breathable fabric
• Micro-stitched and 100% seam taped 2-Layer construction
• Angel-Wing Movement™
• DriClime® Lined Collar and Chin Guard
• Elastic Draw Cord Hem
• Gripper Elastic Powder Skirt
• Inside water bottle cargo pocket and zip stash pocket
• Laser-drilled WR chest pocket
• Laser-drilled WR Sleeve Pocket
• Mesh Lining
• PitZips™
• Reinforced elbow
• Sized Specifically for Women
• Updated Fabric and Hood
• Zip-off ERG hood
• Zippered Handwarmer Pockets
• Zippin™ Compatible
Marmot Women's Tamarack Jacket Color: Black Size: M Retail $200 $120 Shipped
• Mesh Lining
• PitZips™
• Reinforced elbow
• Zip-off ERG hood
Marmot Women's Slingshot Insulated Jacket Color: White Size: S Retail $250 $150 Shipped
Marmot's best softshell fabric backed by high-quality down makes for a powerful one-two punch with the Slingshot Insloated Jacket for women. Although it's engineered for cold, windy, snowy weather, the clean lines and a thoughtful design make the Slingshot a delight to wear anywhere.
• Shell material: 290 P-250 WINDSTOPPER® Shell 2L
• Lining: Halo N-180 WR
• Insulation: 650+ Fill Goose Down
• WINDSTOPPER®
• Zippered sleeve pocket
• Inside zip pocket secure pocket to store small items
• Zip handwarmer pockets soft fabric to warm hands
• HD brushed tricot collar lining
• 650 Down Fill Power
• Angel-Wing Movement™ allows full range of motion in arms so jacket doesn't ride up
• Weight: 1lb 8 ozs / 680g
Mountain Hardwear Women's Typhoon Jacket Color: Black Size:XL Retail $200 $130 Shipped
We started with GORE-TEX® PACLITE® and designed a detail rich,lightweight backcountry shell to keep you dry in a torential downpour. Fully waterproof and extremely breathable.
• GORE-TEX® Paclite Mini-Ripstop
• GORE-TEX® Paclite Shell waterproof laminate
• Articulated sleeves
• Usage:Superlight Backcountry / Rainwear
• Center Back Length:26"
• 13oz/371g
Patagonia Women's Rain Shadow Jacket Color: Black Size: L Retail $150 $90 Shipped
Staying inside isn't the only way to stay dry -enjoy the trails in all conditions with fully seam-sealed waterproof/breathable protection. The Rain Shadow Jacket, now with an improved fit, is made from a packable and lightweight 2.5-layer tear-resistant nylon fabric with a waterproof/breathable H2No® barrier and Deluge® DWR (durable water repellent) finish. On the inside, a raised pattern diffuses and channels moisture away from the skin, aids in hassle-free layering, and enhances long-term durability. Features include a helmet-compatible, roll-down 2-way-adjustable hood; a storm flap with rain gutter over the center-front 2-way zipper and pit zips; water-resistant zippers on handwarmer pockets; partially elasticized self-fabric cuff tabs and a drawcord hem.
• An essential 100% waterproof/breathable 25-layer hard shell for hiking and trekking
• 2.5-layer, 2.5-oz 100% nylon with a waterproof/breathable H2No barrier and Deluge® DWR (durable water repellent) finish
• H2No® waterproof/breathable 2.5-layer tear-resistant fabric
• Interior surface texture channels moisture away from skin, protects the waterproof barrier from abrasion and slides easily over layers
• Roll-down, 2-way-adjustable hood
• Center-front zipper with storm flap
• Reverse-coil DWR-coated pit zips with storm flap
• Pockets: two handwarmer with PU coated zippers
• Self-fabric cuff tabs; drawcord hem
• Ideal Uses: Wet-Weather Hiking, Trekking, General Mountaineering, Anything Rainy
• Regular fit
• 346 g (12.2 oz)
