Weekend fun...or work I guess.
thatkid
Post by thatkid »
Just pictures really.
Sand blasting away for hours.
Dillon reverted back to childhood memories of being locked away...that or the powder messed with his brain.
Pretty white (Where's Mega?? :) )
Do YOU Scopper?
shredex
Re: Weekend fun...or work I guess.
Post by shredex »
ooo, i like the white!
wheres reelrazor its more like lol.
you should powder the triple trees you got!
Post by sweekster »
Damn..that looks goooooooooooooood. Nice work. Now somebody buy that stuff already.
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
Damn that stuff looks good!!! Are you set up for red? Id love to get a set of steel engine cover bolts coated red. Mine look nice but aluminum is useless for holding torque. And rear rotor bolts if ya got em.
haunter
Post by haunter »
sexy
mszilves
Level 1.5
Level 1.5
Post by mszilves »
That turned out awesome! Can't wait for those parts to arrive!
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
mszilves wrote:That turned out awesome! Can't wait for those parts to arrive!
I know you need some sexy white powdercoated parts to go with your sexy white bike!
Upgrades:
thatkid
Post by thatkid »
mrfreeze5 wrote:Damn that stuff looks good!!! Are you set up for red? Id love to get a set of steel engine cover bolts coated red. Mine look nice but aluminum is useless for holding torque. And rear rotor bolts if ya got em.
I can do red. I'll do a few samples cause it's not a deep red. You can decide if you want them done. Otherwise I should have some candy red on order shortly.
Do YOU Scopper?
