Buddy, you 've helped me very much!!!! Thanks a lot for the info. One of these days i'm gonna check my TCI unit in an electronist. Thanks again buddytrifgeorge wrote:about that TCI unit.... i had the same problem. go to an electronist. he will know what to do. the thing is that the TCI unit has 2 fast switching transistors inside of it which are responsable for the timing on each coils. One transistor will send a signal to the coil on the left. The other one will send a signal to the coil on the right. Now the coil on the left provides sparks for pistons 1 and 4. The coil on the right provides sparks for pistons 2 and 3. If one of the transistors inside the TCI is burned or not working at it's optimum specs the sparks on the pistons that he is in charge of , are going to me missing or are going to be too weak to set the fuel mixture off.That is what is happening with your TCI unit. It's a cheap and easy fix if it's done by someoane qualified.I'm going to try to post some pics with the TCI unit.
the one surrounded with red was the BAD transistor. It was responsable for the sparks from pistons 2 and 3. Got it replaced. Make sure to tell the electronist to put some cooling paste between the transistor and it's heat sink.
Just fix a 750 FZR
Re: Just bought a 750 FZR
Today the decals were ready.
And i found necessary to aplly one more coat of white.
This is the last white covering
I asked Nikos today, and he told me that he uses a simple filler. It's nothing special. As for the trade name, even if i tell you, it's a Greek companys. So, it is something you can't find there.cad600 wrote:What product are you using as the filler?
Of course, if you like to apply filler on plastcs, you have to apply plasticizer first.
It is a simple filler though.
Guys,csofos wrote:I asked Nikos today, and he told me that he uses a simple filler. It's nothing special. As for the trade name, even if i tell you, it's a Greek companys. So, it is something you can't find there.cad600 wrote:What product are you using as the filler?
I would say that the same filler that is used on the plastic bumper of Jap imports that get "customed" would be ok for the Job.
Trifgeorge:- Trust a George to get the facts on a "complex" repair thanks from all of us on that one
Y-G
- trifgeorge
- Level 2.0
i'm glad i could help a FZR owner!csofos wrote:Buddy, you 've helped me very much!!!! Thanks a lot for the info. One of these days i'm gonna check my TCI unit in an electronist. Thanks again buddytrifgeorge wrote:about that TCI unit.... i had the same problem. go to an electronist. he will know what to do. the thing is that the TCI unit has 2 fast switching transistors inside of it which are responsable for the timing on each coils. One transistor will send a signal to the coil on the left. The other one will send a signal to the coil on the right. Now the coil on the left provides sparks for pistons 1 and 4. The coil on the right provides sparks for pistons 2 and 3. If one of the transistors inside the TCI is burned or not working at it's optimum specs the sparks on the pistons that he is in charge of , are going to me missing or are going to be too weak to set the fuel mixture off.That is what is happening with your TCI unit. It's a cheap and easy fix if it's done by someoane qualified.I'm going to try to post some pics with the TCI unit.
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
R6 pilot seat
KOSO mirrors
H1 HID
Today. i cover the surfaces that are going to stay white.
And i also apply with primer tha gas tank
trifgeorge wrote:i'm glad i could help a FZR owner!csofos wrote:Buddy, you 've helped me very much!!!! Thanks a lot for the info. One of these days i'm gonna check my TCI unit in an electronist. Thanks again buddytrifgeorge wrote:about that TCI unit.... i had the same problem. go to an electronist. he will know what to do. the thing is that the TCI unit has 2 fast switching transistors inside of it which are responsable for the timing on each coils. One transistor will send a signal to the coil on the left. The other one will send a signal to the coil on the right. Now the coil on the left provides sparks for pistons 1 and 4. The coil on the right provides sparks for pistons 2 and 3. If one of the transistors inside the TCI is burned or not working at it's optimum specs the sparks on the pistons that he is in charge of , are going to me missing or are going to be too weak to set the fuel mixture off.That is what is happening with your TCI unit. It's a cheap and easy fix if it's done by someoane qualified.I'm going to try to post some pics with the TCI unit.
YOU HAVE BEEN IMMORTALISED IN THE WIKI HOW-TO SECTION
- trifgeorge
- Level 2.0
Cool ! Thank you!
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
At last i paint the blue today!!!!!
Nikos in action
That's it before decals been applied
And after decal application
The undertail and the one side of the fairings have my gym's logo. It says "ATHLETIC GYM everything can happend". Now if you take a closer look to see with witch part of his body that bodybuilder lifts the weights, you 'll probably find out why it writes that!!!!!!!!
And not to forget the Yamaha's good old concept: "Genesis". This is where all have been started.
Nikos in action
that looks hot
My FZR6 Rebuild
My FZR6 Rebuild
Good work as usual. You HAVE to take a pic with all of the FZR's together when this one is done Cris. Awesome job so far.
Thanks buddy! I will, be sure about it. And i 'll wear the fzronline.com t-shirt too!!!!sweekster wrote:
Chris,csofos wrote:Thanks buddy! I will, be sure about it. And i 'll wear the fzronline.com t-shirt too!!!!sweekster wrote:
great stuff you had better wear the tee shirt or someone will "key" your paint :cop
The paintwork completed......
That's a spot i have to fill with something
This motorcycle is dedicated to the memory of my friends Jack. Most of you, probably remember the story....
Many could say that typing a dead man's name on the bike might be a bad luck. Not for me though. I think it's a guardian angel.
holy CRAP that looks amazing
Upgrades:
