1991 fzr600 problem
1991 fzr600 problem
what do i need 2 do i cleaned the carbs the bike hates low rpms surges a lot . I have 2 crank the throttle 2 3000 2 get the bike going . Ok if i crank the throttle hard she will go and go well
Re: 1991 fzr600 problem
I would run some seafoam and try to clean some things out.
Issues you may have:
- You might not be firing on all cylinders
- Your carbs may need to be sync'd
- Your IMS (Idle Mixture Screws) may need to be adjusted
- The plugs may need to be regapped or replaced
it firing on all cyl all 4 pipes get hotragedigital wrote:I would run some seafoam and try to clean some things out.
- Your carbs may need to be synced
yes carbs need synced
iv got it at 3 turns out
plugs brand new gaped at 30
just put sea in it 15 mil ago and i run 93 oct gas
Is your engine knocking? If not, then don't use Premium gas. You'll get better performance from the 89 octane.
3 turns out is a starting point. They could still be several hundred degrees different at idle. Borrow someone's IR temp gun to check the header temps.
lafaro
- 100+ Posts
- Location: currently north carolina/ hometown fair lawn new jersey
you will get better proformance from 89? i didnt know that can u elaborate on that a little rage
1999 fzr 600 *vance and hines can and header*stage 2 jet kit*r1 front seat*frame painted gloss black*"ducati" style mirrors with integrared smoked blinkers*r1 tail and pit-eck fiberglass undertail molded into a 1 piece tail and undertail*black powdercoated brake and clutch levers*Bridgestone BT-014*single headlight 92 front fairing swap*powdercoated black engine covers(TK)*aluminum coolent tank(modking)*2007 cbr1000rr rear seat*zero gravity smoked windscreen cut short*lowered front 2"
Hating low rpms that means low fuel at low rpms. I think your carbs need of some cleaning. And i mean serious cleaning. You have to take them off and take them appart. Then you have to vaptize them in carb cleaner (the vaptizing time differs in each cleaner). Spray carb cleaners don't do good job. The emulsifier tubes are plugged in most of the cases.
When you assemple them again, you have to synchronize the throtlle valves. And the mixture screw is 3 turns out as ragedigital said.
Octane rating is not a measure of the fuel's heat release, but rather it's knock resistance. A higher-octane fuel is actually HARDER to burn, but it's reluctance to detonate allows you to increase compression and / or spark advance to a level that would cause knock, ping, and eventually BANG with a lesser octane number. Turned around, this slower burn speed means that a more lightly tuned engine will make LESS power on higher octane fuel.lafaro wrote:you will get better proformance from 89? i didnt know that can u elaborate on that a little rage
A stock FZR should do fine on 87. If it knocks, go to 89. 93 is probably costing you mileage and performance.
Don's right as usual.DonTZ125 wrote:Octane rating is not a measure of the fuel's heat release, but rather it's knock resistance. A higher-octane fuel is actually HARDER to burn, but it's reluctance to detonate allows you to increase compression and / or spark advance to a level that would cause knock, ping, and eventually BANG with a lesser octane number. Turned around, this slower burn speed means that a more lightly tuned engine will make LESS power on higher octane fuel.
I will add that even with a spec of 12:1 compression ratio, and FZR engine has such a small and compact combustion chamber(basically perfect) that 89 octane is fine for any FZR engine that hasn't had serious compression modifications (big-bore/afermarket cams/head skimmed bunches) or that hasn't had the timing advanced a whole lot (and why would anyone do that unless the compression had been raised a bunch?).
But to get back to your original complaint....one thing in your initial post is sticking with me:
I am unclear (wow?) on what you are saying here.....did it do this before you 'cleaned the carbs' ? Or only after?KASH wrote:what do i need 2 do i cleaned the carbs the bike hates low rpms surges a lot .
ok update i took the carbs off again cleaned every port anything that would come out i took out. I got a heat reader what is the pipe heat supposed 2 be? Right now i have it at 115 on the 1st 2 pipes 250 on the other 2. idle is 1500rpms
when i got the bike it was real tough 2 get it 2 go. i had 2 crank the throttle 2 get it going it would chug chug then vrooooooooomreelrazor wrote:Don's right as usual.DonTZ125 wrote:Octane rating is not a measure of the fuel's heat release, but rather it's knock resistance. A higher-octane fuel is actually HARDER to burn, but it's reluctance to detonate allows you to increase compression and / or spark advance to a level that would cause knock, ping, and eventually BANG with a lesser octane number. Turned around, this slower burn speed means that a more lightly tuned engine will make LESS power on higher octane fuel.
lafaro
- 100+ Posts
wow very usfull to know thanks once again guys for the info.
How does it run now?KASH wrote:when i got the bike it was real tough 2 get it 2 go. i had 2 crank the throttle 2 get it going it would chug chug then vrooooooooom
better but not quit right im going 2 try and tune it in tomorrow
ok put the carbs on a 24 hr soak right side pipes are at 450 left side are at 350 . I still need 2 sync the carbs but it runs much better
