cheap adjustable link for r6 swingarm
i was tring to mount the top of my shock today but i dont have anything to bend the steal right so it looks go so i had to go with a straight peice pushing the tail up high so i was thinking of a lowering link thats adjustable and i came up with these female rod ends and a half in threaded rod suposed to hold 8400 lbs and i can set my own hight the were only 14 dollars shipped off ebay for 2
there not very wide so you would have to cut some spacers to fill the bracket.
- shredex
- 2000+ Posts
Re: cheap adjustable link for r6 swingarm
someone was making these on here...
you cant get much adjustment with those though.
get ones made out of 1/4" steel or high grade aluminum and have three holes drilled for adjustment
the r6 swing uses only one link in the middle. are you thinking of the fzr links with the 2 on the sides. those are the only ones i saw on here (for the r6 shock upgade). they wouldent work for this
