First thing I do is take off the airbox to see if there is any gas pooled (leaking float valves, but I highly doubt it) in case it's hydrolocked. Nothing, nice and clean valves.
Next I go to take off the starter clutch cover to see what's going on... I find this: now does anyone know why/how in the world this happened, and what might have caused it? I notice that one of the reductions gears is worn, would that be enough? I'm at a loss... and I can't even start or run the bike like this! So at the same time, I guess I need the crank starter gear, and the worn reduction gear? Will I even be able to source these parts from bikebandit etc?
Broken teeth
Teeth sitting in cover
Worn reduction gear
