How to Fix brake resoivor/cylinder problem
Re: How to Fix brake resoivor/cylinder problem
"All pictures contained within this listing just for illustrated purpose.
The pictures don't represent true size, and slight changes in shape and color may occur due to the natural construction of this item. "
"VERY IMPORTANT!!!
WHAT YOU SEE IN THE PICURE WILL BE WHAT YOU GET"
Nice...
That's the chain you need; just not sure you want to deal with people like that.
"VERY IMPORTANT!!!
Nice...
What type of chain do I need for a 13/55 setup?
The chain is the chain, a 428; you'll probably need to trim some links off.
Now. You're dropping from a stock 19 front sprocket to a 13 sprocket, a reduction of 32%. That also means your engine speed for a given road speed and gear is going to go up by 46%. Do you really need this? First gear may be unusable, highway speeds even in 6th gear may be screaming.
Why do you want to change your gearing so drastically?
Wait a minute...We're talking about an FZR600, right? If so, the stock gearing is 15/45 with a 530 chain-not 428.
I don't believe the nice man has ever actually specified what his bike is; I've been going off his description of his current gearing. I've never heard of a 530 55-tooth rear sprocket stock on ANYTHING, but the 400s were stock with 55-tooth 428s.
Sorry guys I wasn't specific. 1998 FZR-600. I just picked it up for $650 and it needs a little work. It was the only thing I could afford for my first bike with my own money since my parents don't stand behind me on motorcycle riding. I did not gear it like this, this is simply how I bought it.
So a 428 chain is what I'm looking for? Would it be best to go back to stock gearing? What about just changing the rear sprocket back down to something useable?
Like Sweekster said, if you're working on a 600, stock gearing is 15/45 with a 530 chain (or 520 conversion). Ignore everything discussed to date about 428 chain and 55 tooth rear sprockets.
I checked out the sprockets and it came out to a 13/55 unless there is more to it than just literally counting the teeth?
Should be stamped on the side of the sprocket...
ouch, now I feel like an idiot... but yes it says 55 on the rear sprocket
That's basically stunt-bike gearing. Is that what you want? Easy wheelies-no top speed? As Don said above..."first gear may be unusablel".asdfghwy wrote:ouch, now I feel like an idiot... but yes it says 55 on the rear sprocket
That definitely isn't what I want. This is my first bike and I can only imagine the kind of problems I'll have with such rigorous gearing. If I changed the rear sprocket down to 44 or 45 would that be sufficient enough to get it as close to stock as possible?
Also, while running I realized the front sprocket was moving at what seemed a normal pace but at sometimes it would "bog" down (lose speed) then catch back up. What could that mean?
* there is no chain on the bike currently.
No chain? You could get a 520 conversion kit from Sum of All Parts <--click there. Comes with new front and rear sprockets along with a chain. I also suggest getting a rivet type master link (<--Click there) as well.
How hard is a new sprocket / chain install? I know a chain install is around $40 which I assume it's something worth having a shop do but what about sprockets?
