steering stem nut size...?
haunter
Post by haunter »
plz and ty :deal:
reelrazor
Wrench
Wrench
Re: steering stem nut size...?
Post by reelrazor »
Outside diameter = 40mm
Inside diameter = 24mm
Notch depth = 2.5mm
Notch width (male) = 13.7mm (this is average as it seemed to vary between 13.6ish to 13.75ish)
Notch width (female) = 6.5mm
Circumference = 127mm (I figured this might help to get the correct arc size on the tool)
Nut thickness = 7mm
(courtesy of FZRBrandon)
haunter wrote:plz and ty :deal:
H,
looks like you need on of these :- Ebay No.:- 370093051850
haunter
Post by haunter »
reelrazor wrote:Outside diameter = 40mm
Notch depth = 2.5mm
Nut thickness = 7mm
H,
whoooooooooooooooooa boys
I think there is some confusion
I just need to know the size of socket I need to bring to remove the nut on the top of the steering stem that holds the upper triple in place
its an hour round trip if I dont have the right size socket from bike to tool store so I dont want to waste trips thats why Im asking............
reelrazor
Wrench
Wrench
Post by reelrazor »
Ahh, thought you needed the ring nut size.
On the crown nut, I am seeing 27mm from flat to flat.
haunter
Post by haunter »
hehehe yeah I didnt really explain it all that thoroughly
thanks dude, I'll source said socket before I head back out.
guess I should finish painting the wheels so I can get tires mounted before I both swapping forks and swinger though........
