With just 9Lbs of down force on the handle, you can have the spring off the valve in under 15 seconds ! then you simply slide the compressor over to the next valve and repeat the process.
With this compressor you can have ALL springs removed in under 5 minutes, which is extremely important at the race track or engine shop. The compressor head design will not allow the keepers to fall down into the oil passages, preventing engine teardown to find lost keepers further saving time.
