what to replace when doing fork seals?
Cursed94FZR600
Re: what to replace when doing fork seals?
reelrazor do those sides wear out or are those optional to replace?
The stock 10w oil is pretty light and if you are a bigger guy like myself you'll find that the front end is a little soft and spongy. The heavier oil will help stiffen front end and make it much more stable. Short of buying new progressive or racetech springs, this along with a longer preload spacer, can help you fine tune your front end.
Cursed94FZR600
mk good to know. thanks
They wear for sure if they run dry, and you can often see 'braking wear' in them on bikes with quite a few miles.Cursed94FZR600 wrote:reelrazor do those sides wear out or are those optional to replace?
If they look good on inspection, don't sweat it.
They are teflon coated steel, and if the teflon is worn thru anywhere, you have metal on metal contact between the bushing and the inner fork tube-not to mention the stiction that causes.
- ghettomedic505
- 100+ Posts
sweekster already answered but it worked better cause it made the front end significantly stiffer than it was.Cursed94FZR600 wrote:better how?
OH I THINK I DROPPED MY MONKEY
Cursed94FZR600
ok cool, so if they look like they are in good shape it's ok to leave em.
Cursed94FZR600
i have another question i thought of last night. could i break loose the bottom bolt before draining the fork. i'm not talking all the way out but if the upper section of the fork will prevent it from rotating, do you think it would work to loosen the bottom bolt first?
Yes. See my earlier post. I have never made/used a damper rod holding tool. It's less messy to drain the fork, but you CAN do it that way.Cursed94FZR600 wrote:i have another question i thought of last night. could i break loose the bottom bolt before draining the fork. i'm not talking all the way out but if the upper section of the fork will prevent it from rotating, do you think it would work to loosen the bottom bolt first?
Cursed94FZR600
just looked back now, must have missed that little part earlier. Thanks for all the help. Now i get to wait a week and a half for the parts to get here.
