having a bit of trouble selecting gears sometimes, this happens more frequently when the bike is cold but it still happens too much for my liking when the bike is warm.
The problems hard to explain, it has a couple of different issues, for a start sometimes when slowing down to change into first it will click into neutral instead. Other times it will go into first, but as i pull away it will jump into neutral and just rev and not move. a similar thing happens when changing up, more often that not the bike prefers to go into neutral than second.
At first this was just an annoyance, but it seems to be getting worse and is at the point where i'll go to pull away and lose my balance and nearly come off due to no power. I've tried adjusting the clutch but no luck, also played around with the gear lever with no luck.
aaand now its gotten worse, i'll be changing down gears and there's just nothing there, the pedal is completely slack.
The part i've been told could be the culprit is the de-tense spring? this means nothing to me and i've no idea what it is
opinions please
