Target's bike : more pics, moved thread
- abs929cbrrr
- 1000+ Posts
Re: Target's bike : more pics, moved thread
ok, how on earth did you get a 03-04 636 seat cowl to fit on the 99-02 R6 tail...you got some explaining to do my man!
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
I did that.
well, i still have some cosmetics to do, but another small update.
I did that.
The tape makes all the difference. Nice
- shredex
- 2000+ Posts
just need USDs with painted blue tubes and it will be perfect!
clearer pics
I did that.
Thinking back on how your bike used to look to the way it looks now...simply impressive. And that rim tape really breaks up the monotony of all black wheels. Did I mention the cowl looks great?
China_Racer_1
- Level 5.0
Well the bike looks great for sure. Color be damned I look more at the lines and how it all flows and it flows well. IMHO
The TZR swinger looks great as well. I should have kept it ha ha
Was it hard to get it i there and make it right? I am still working on my F3 wheel and 3TJ swinger.
Look forward to pics when the decals go on.
The lower shock mount was the hardest part, and sadly i am still running the bastardized thing i made, which consists of a frankenstien creation of tzr/R1/custom parts bolted together. it works, but i want to have a nice one made eventually. The upper shock mount was pretty easy, i had one made that spanned the front part of the subframe, and hung down between, and bolted that on. the swinger actually fits fine, and with the fzr600 engine, it lines up perfect if you just use a spacer on the one side. however it is a bit longer than stock, i think i last measured it at 57 3/4 bolt to bolt, but that was just stretching a tape measure between the two. i have a new plan for the bodywork, before the decals go on, and i am currently working on getting some money together for my first track day, so i think i will wait to make the finished product until after that.
I did that.
http://www.fzronline.com/forum/viewtopi ... =21&t=7032
figures i would add this to this thread to cross reference. kinda a cheap picture whore attempt. but i gotta be me
I did that.
